Stoopid Question
DigitalFusion
Posted: October 22, 2004 at 9:06 PM / IP Logged
Hey All,
  A friend and I are installing a remote start/alarm in his 98 Chev Pickup.  The diagram for the alarm goes like this:
RED / Black = To ON
Blue/White = To ACC
  Trouble is that the wiring diagram we have goes like:
Ignition = Pink
Ignition2 = White
ignition3 = Brown
Accessory = Orange
  We are not sure which wire to wire to which switch position.  When we click the key all the way back, we get voltage at brown.  When we click to the first position we get voltage to white, and on the third position we get power on everything.
mo12v
Posted: October 22, 2004 at 9:28 PM / IP Logged
If all U have is those 2 wires from RS
The way I see it:
Ignition = Pink   =  RED / Black = To ON
Ignition2 = White  = SPDT  RELAY
ignition3 = Brown  =  Blue/White = To ACC
Accessory = Orange  = SPDT  RELAY
MO
DigitalFusion
Posted: October 22, 2004 at 10:15 PM / IP Logged
thanks... we will give that a try
DigitalFusion
Posted: October 23, 2004 at 3:56 AM / IP Logged
the remote start is not working, the truck starts, but dies right away... we found this information for the alarm:
Stoopid Question -- posted image.
draasch
Gold - Posts: 2,172
Posted: October 23, 2004 at 12:06 PM / IP Logged
what unit are you installing??????????????????????/
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
hlude1
Member - Posts: 23
Posted: October 23, 2004 at 2:22 PM / IP Logged
The unit is the magicar 8100
DigitalFusion
Posted: October 23, 2004 at 2:31 PM / IP Logged
hey tim, did whats-his-name email you yet?
hlude1
Member - Posts: 23
Posted: October 23, 2004 at 2:33 PM / IP Logged
sure did
draasch
Gold - Posts: 2,172
Posted: October 24, 2004 at 1:34 PM / IP Logged
did you get everything working???
will the truck start with the key in the ign.???
if it does and will not with they key out, then you need to bypass the pass system....
let us know.....
Good Luck
David
Ace Security
813-376-9778
Tampa
Ravendarat
Platinum - Posts: 2,806
Posted: October 24, 2004 at 1:54 PM / IP Logged
I am banking on a problem with the passlock, either the module is defective, not installed properly, or just not installed. Did you use a bypass module?
Friday, January 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
