delta pro2k combo
chevy
Posted: October 06, 2002 at 2:44 AM / IP Logged
someone pls help....1st timer...
vehicle- 01 chevy silverado...i'm installing a delta pro2k combo alarm w/ remote starter...my truck has a passlock 2 immobilizer system...how do i connect my unit to a DEI 555L...the pro 2k installation guide state that the orange (armed & start output) connect to a 30 amp relay for starter kill output. Does the 555L handle the relay or do i need both?...Sorry if q is unclear, but i'm confuseddelta pro2k combo -- posted image....also, can i connect to my factory alarm disarm thru the BCM...if yes, whaat is the pin location
thx, any and all help is greatly apprecaited!!!!!
willie
Moderator - Posts: 12,488
Posted: October 06, 2002 at 9:11 AM / IP Logged
  • FCTRY ALRM DISARM              lt.green            | -  |drivers kick
  • Also found in the purple plug of the BCM
  • The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle.
  • You need to hook up the STARTER DISABLE wire ( ORANGE ) on the Pro2K to a 30/40 amp relay like this diagram: https://www.the12volt.com/relays/page2.asp#sk1
  • Make sure that when you attach the starter wire for the Pro2K it's attached on the motor side of the relay, not the keyside (  ignition side ) of the relay
chevy
Posted: October 06, 2002 at 4:15 PM / IP Logged
thx jeff,
info helped...new problems,
-vehicle starts w hood open or close.....do i need to install a trigger pin?.........
willie-  help apprecaited..............
Posted: October 06, 2002 at 4:57 PM / IP Logged
Yes, you need to install a hood pin switch or a mercury switch . Connect this to the HOOD / TRUNK wire on the Delta 2000.
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
