integra with clifford 3.5 alarm
Lee_Thao
Member - Posts: 16
Posted: November 04, 2004 at 3:02 AM / IP Logged
i was wondering if anyone knows to how install the clifford matrix 3.5 alarm into a 96 acura integra gsr. there are so many wires and i don't know which to connect and which is not needed. I also don't know if i need to wire up the diodes and resistors or not. And one more thing, i know that it's illegal to have a manual transmission to have a autostart but if someone could show me how to install that too it would be appreciated. thanks.
Lee
Ben.c
Member - Posts: 29
Posted: November 04, 2004 at 3:50 AM / IP Logged
 if you go to the left hand side of the web site and look under general information and click on vehicle information you will find a search box just sect the year and make of vehicle from there and selct alarm info for your vehicle.
note its not advisable to hook up remote start to a manual but so you know the wire from your alarm for the nuetral sfaety switch must be grounded or the remote start wont work but i suggets your try to rig up some kind of spring loaded switch on your gear shifter so it only provides ground when in nuetral .( this is hard be can be done )
ozy installer
kgerry
Platinum - Posts: 3,455
Posted: November 04, 2004 at 10:02 AM / IP Logged
actually DEI has a new module out that allows integration into manual vehicles, although i think it's only available in Canada.... pity
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Lee_Thao
Member - Posts: 16
Posted: November 04, 2004 at 12:51 PM / IP Logged
thanks for the help, i see what i can do. in the mean time if anyone else knows a easier process of bypassing manual autostart please let me know.
Lee
Wednesday, July 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
