Posted: November 14, 2004 at 10:26 PM / IP Logged
Posted: November 15, 2004 at 9:49 AM / IP Logged
Posted: November 16, 2004 at 2:37 AM / IP Logged
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
IF YOUR WORKING ON A CAR THAT HAS NEGATIVE LATCH TRIGGERS, YOU WOULD PUT ONE OF GREEN / WHITE TOGETHER WITH GROUND. AND THE OTHER GREEN / WHITE TOGETHER WITH THE BROWN WIRE OF THE ALARM. THIS WILL GIVE NEGATIVE SIGNAL TO TURN ON THE DOMELIGHT IF ITS A NEG DOMELIGHT AND NEGATIVE DOOR LATCH
IF YOUR WORKING ON A CAR THAT HAS POSITIVE DOOR LATCH TRIGGERS, YOU WOULD PUT ONE OF THE GRN/WHT WITH BATTERY (RED WIRE) AND THE OTHER GRN/WHT WITH PURPLE (POSITIVE DOOR LATCH WIRE OF THE ALARM) IF POSITIVE IS REQUIRED TO TURN ON YOUR DOME LIGHT.
HERES ANOTHER EXAMPLE..FOR INSTANCE, FORD EXPLORER1998.
IF YOU PREFER TO TAG THE LT.BLUE/WHITE(NEGATIVE DOOR TRIGGER) INSTEAD OF THE BLACK/ BLUE(DOME LIGHT DELAY WIRE). YOU WOULD TAG YOUR BROWN FROM THE ALARM TO THE NEGATIVE DOOR TRIG(LT.BLUE/WHT) AND USE ONE OF THE GRN/WHT TO POWER(B+) AND THE OTHER GRN/WHT ALONE TO THE POSITIVE DOME LIGHT WIRE.
HOPES THIS ALL MAKES SENSE.
THE GRN/WHT IS AN OUTPUT SIGNAL FROM THE ALARM, SO WHICH EVER GRN/WHT YOU PUT TO EITHER B+. OR NEG(GROUND). YOU WILL GET THAT SIGNAL ON THE SECOND GRN/WHT
