Dodge Diesel Auto Starter
Tim1609
Posted: November 21, 2004 at 8:49 AM / IP Logged
Thank You, daniel2002p for the wiring diagram. But, I was told that the 2500 old body style is not the same wiring as the new body style. I need a diagram for a new body style 2003 2500 Std cab with a diesel. Any help would be appreciated. Thank You, Tim
genehewett
Copper - Posts: 151
Posted: November 24, 2004 at 2:47 AM / IP Logged
     Tim1609 see if this will work for you.
DODGE / RAM PICKUP / 2004 / Remote Start
12volts red (x2)  +  ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition pink/white  +  ignition harness
Second Ignition pink/lt. green  +  ignition harness
Third Ignition pink / YELLOW (10 awg) (3rd acc) +  ignition harness
Notes: This wire is not required for remote start. It only provides power to the power window circuit.
Accessory dk. blue & pink/yel (16 awg)  +  ignition harness
Second Accessory pink / YELLOW (14 awg)  +  ignition harness
Keysense PURPLE / tan  -  ignition harness
Power Lock PURPLE / dk. green  -  driver kick, door harness
Notes: Lock is negative trigger thru an 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.
Power Unlock same wire as power lock
Lock Motor lt. green  5wi driver kick, door harness
Unlock Motor tan/lt. green  5wi driver kick, door harness
Parking Lights+ wht/yel (L), wht/gray (R)  +  harness at top of driver fender
Parking Lights- WHITE/ lt. green  -  headlight switch
Notes: Parking lights are negative trigger thru a 249 or 330 ohm resistor. MUST use a relay.
Hazards WHITE/ yellow  mux steering column
Turn Signal(L) WHITE/ yellow  mux steering column
Turn Signal(R) WHITE/ yellow  mux steering column
Reverse Light WHITE/ lt. green  +  inside mirror or plug by PCM
Notes: The PCM is on the passenger side firewall.
Door Trigger see notes  -  see notes
Notes: The driver door trigger is purple and the driver side rear door is PURPLE / orange. These wires are in the driver kick panel. The passenger door trigger is PURPLE / white and the passenger side rear door is purple / YELLOW. These wires are in the passenger kick panel. Use all four wires and diode isolate each. See DirectFax document 1076 for wiring information.
Dome Supervision yellow/lt. blue or yellow/org  +  driver A pillar or cluster
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm PURPLE / lt. blue  -  driver kick, door harness
Notes: This will also do door locks. Arm/lock is negative trigger thru a 2K ohm resistor. Disarm/unlock is negative trigger thru a 480 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays.
Factory Alarm Disarm same wire as factory alarm arm
Disarm No Unlock same wire as factory alarm arm
Tachometer dk. blue/gray  ac  PCM, orange plug, pin 34
Notes: The PCM is on the passenger side firewall. On diesel models the tach wire is at the ECM on the lower driver side of the engine, 60 pin plug, pin 24.
Wait to start see DirectFax document 1091
Brake Wire WHITE/ tan  +  brake pedal switch
Parking Brake dk. GREEN / WHITE  -  parking brake switch
Horn Trigger dk. GREEN/ purple  -  steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Dodge Diesel Auto Starter -- posted image.
Immobilizer Bypass Module:Required: YesType: Sentry KeyPart #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
< language=>
Monday, April 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
