tachometer problems
park311
Member - Posts: 15
Posted: October 11, 2002 at 5:52 PM / IP Logged
okay...I'm installing a crime stopper cs-2011rs in a 99 Nissan Sentra and I'm having trouble finding the right tach hook up...I have 2 wire diagrams and both say the location of the black coil is in the instrument panel and one says the wire is green and the one on this web site says the wire is GREEN/ YELLOW well...I didn't find the coil and the wires around the ecm I found a green wire, but it doesn't work....so I was wondering if anyone could help me find the correct tach hook up..please
securinu
Silver - Posts: 772
Posted: October 11, 2002 at 6:07 PM / IP Logged
just go to one of the injectors to the odd color and that should work the same as tach.
djfearny2
Silver - Posts: 810
Posted: October 11, 2002 at 6:09 PM / IP Logged
listen your ingintion coil is actually the disrtibuter cap you know the part where all the sparkplug wire plug in to from each sparkplug. that is where it is usually located.
TachGreen (AC) Distributor or Blue/Orange Position 3 Center Console
Jon
Installer/Help Technician
---coral springs florida---
park311
Member - Posts: 15
Posted: October 11, 2002 at 9:11 PM / IP Logged
hey thanks I think I have the tach problem solved, but I believe I am not hooking the parking lights up right either....can wire printout says the RED / blue wire at the top of the fuse box....since I am not having luck with that can it be found running from the headlight switch on the steering column....and also a ? about the DMM (mulitimeter)..I know you set it on on DCV, but what #...200, 2, 20...thanks.....I ran the tach for the blue/orange wire by the way
Eliseo
Member - Posts: 14
Posted: October 11, 2002 at 9:24 PM / IP Logged
 What you need to do is hook up the parking lights wire to the RED / blue wire at the parking light switch. The DMM should be set 20 that shows the max volts the meter will read.
Late, E. Mendez
park311
Member - Posts: 15
Posted: October 11, 2002 at 10:34 PM / IP Logged
ookay I have the RED / blue wire hooked up where the parking light switch is so I know I have that hooked up for sure....and I have the wire for the tach hooked up directly to the instrument cluster going to the speedometer..all that junk...I've tried both the blue/orange wire right there and the green wire and a GREEN/ YELLOW wire...but when I start the car and push and hold the valet switch for a few seconds the parking lights are not flashing to let me know I am hooked up to a valid tach source..am I still doing something wrong about the tachometer? by the way my siren keeps going off and I can't seem to fix that and the wires are not crossed or mixed up....I'm starting to go crazy
Eliseo
Member - Posts: 14
Posted: October 13, 2002 at 1:17 AM / IP Logged
 I have the blue/orange tach wire needs to be hooked up at the (ECM) Engine Control Module which is located behind the center console.
Late, E. Mendez
