Never have a dead battery again
artruckcustoms
Posted: November 26, 2004 at 12:32 PM / IP Logged
I need some help building a voltage meter to activate my remote start when the voltage gets to low.  My remote start needs a neg pulse to start.  I want to add a meter to automaticly start my truck when the voltage gets to 11v.  If anyone knows where to build one or buy one that would be great.
SoundFX411
Copper - Posts: 153
Posted: November 26, 2004 at 1:50 PM / IP Logged
You should look at the Omega RS-4LX. It has a feature that senses the voltage of the battery. If it drops below ( I think 11 volts )it will start the car to charge the battery
SoundFX
gatf4
Member - Posts: 20
Posted: November 26, 2004 at 8:05 PM / IP Logged
Thats a great idea but why not start it when it drops to 12 volts?
TriOptimum
Member - Posts: 12
Posted: November 26, 2004 at 9:06 PM / IP Logged
These look kind of dangerous to me.. what if you park your car in your garage? It could kill you in the house with the fumes. Or in a parking garage at a mall or the like, it could get towed... I carry around a battery jump kit, small thing that hooks to the battery terminals to jump it if needed... never have since I upgraded to a red cell brand battery though.
extreme1
Silver - Posts: 1,070
Posted: November 26, 2004 at 10:31 PM / IP Logged
at 11V your car probably won't start, I have mine set to 12.1V and only when I know it's gonna be below -20C.
Mine also has a temp based one that I have set for -25C.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
NowYaKnow
Gold - Posts: 1,217
Posted: November 27, 2004 at 9:33 AM / IP Logged
Agreed no reason to reinvent the wheel there are already several manufactures with this feature already in the system. Both voltage and temperature based.
artruckcustoms
Posted: November 27, 2004 at 10:52 AM / IP Logged
I would have it on a switch so that when I don't want it to start up it won't.  I mostly want it for when I am powering tools from the inverter in my truck, or when I am parked and watching a movie.
Mja1962
Copper - Posts: 119
Posted: November 27, 2004 at 10:57 AM / IP Logged
Some remote starters won't attempt to start the vehicle if the key is in the Accessory position (which it would be in if you're watching a movie), so you have to keep that in mind when deciding how to design a system to do what you're trying to accomplish.
-Michael
draasch
Gold - Posts: 2,172
Posted: November 27, 2004 at 11:20 AM / IP Logged
most inverters have a safety inside that will shut the inverter off when the volts drop coming from the battery........i run my inverter for a while and have never had a problem with the remote start unit needing to start the van....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
