passlock 2 freaking out! velocity!
jeffchilcott
Platinum - Posts: 2,483
Posted: November 26, 2004 at 8:40 PM / IP Logged
Hey guy's interesting thing happened.
Installing an alarm\remote start in a 2001 buick regal
used pldata to bypass
Had a wire wrong somewhere I think the data wire...anyone know what wire for sure?
So car went into protect or whatever it is, and while the pldata was dissconnected Someone tried to start the car....Now relays and such are buzzing under the hood and in the fuse panel, and it wont release the keys.
Anyone HELP???!!!
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
greermodela
Posted: November 26, 2004 at 8:59 PM / IP Logged
try disc.your accessory , turn on ign for 30 min. relearn theft deterent. if ok check all connections.
jeffchilcott
Posted: November 26, 2004 at 9:02 PM / IP Logged
well here is the situation, car has sat for over 20 minutes the key is still lok\cked in the IGN. and the battery is about just about dead
2007 World Record
draasch
Gold - Posts: 2,172
Posted: November 26, 2004 at 9:45 PM / IP Logged
try charging the battery.....it might be doing this beacuse the battery is low....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
jeffchilcott
Posted: November 26, 2004 at 10:17 PM / IP Logged
hey draasch...your right!    We already tried charging the battery and bam    eveything worked except the remote start...i guess thats for another post
2007 World Record
draasch
Gold - Posts: 2,172
Posted: November 26, 2004 at 10:31 PM / IP Logged
whats wrong with the remote start??????
Good Luck
David
Ace Security
813-376-9778
Tampa
extreme1
Silver - Posts: 1,070
Posted: November 26, 2004 at 10:33 PM / IP Logged
the 2001 Buick regal has VATS not Passlock II
but the PLDATA should still work.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
jeffchilcott
Posted: November 26, 2004 at 10:37 PM / IP Logged
the 2001 buick has vats?????I was told before in my wireing diagram and color codes it was passlock 2, was someone wrong?
2007 World Record
gus1
Gold - Posts: 1,013
Posted: November 27, 2004 at 12:31 PM / IP Logged
VATS is rather obvious by the black, visible pellet on the key shank. If so.... toss the PLDATA, wire up one relay, the correct resistance value, and done.
Gus
draasch
Gold - Posts: 2,172
Posted: November 27, 2004 at 12:41 PM / IP Logged
i think jeff has it all worked out......
Good Luck
David
Ace Security
813-376-9778
Tampa
