03 Envoy D.I.C. problems
Patel
Copper - Posts: 86
Posted: December 01, 2004 at 9:57 AM / IP Logged
u can set the Driver Information Center to recall the seat position with one of 3 settings:
1)RECALL OFF (by default)
2)RECALL AT KEY IN
3)RECALL ON REMOTE
now for my problem:
installed a starter on an 03 envoy everything works fine
except for the personal recall settings by the key
i used a GMDAA as the bypass
1)the buttons on the door work fine and recall the both drivers
2)the remotes work fine if setting 3 is programed (see above)
3)if setting 2 is programed the truck doesn't reconize the different keys (custumer says it did b4 the starter was but it)
does anyone know a fix for this or how to program each key to each driver settings.
thanks for any help
kgerry
Platinum - Posts: 3,455
Posted: December 01, 2004 at 11:05 AM / IP Logged
if i'm not mistaken these are designed to recognize the remote transmitter, not the key
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Patel
Copper - Posts: 86
Posted: December 01, 2004 at 11:24 AM / IP Logged
u can set them to respond to either the key or the tranmitter, custommer said it use to work befor the bypass was installed
kgerry
Posted: December 01, 2004 at 3:44 PM / IP Logged
thats funny.... i'm pretty sure at key in for my Envoy means the seat adjusts when it sees the key sense triggered...or by remote.....   so if you programmed easy access exit ( the seat slides all the way back when you cycle the ign off ) then either the seat slides forward when you unlock the doors with the appropriate transmitter or when the key is slid into the ign.......
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Patel
Copper - Posts: 86
Posted: December 01, 2004 at 6:18 PM / IP Logged
yes thats right
ur last post sounds correct to me
i need the car to respond to each repect keys as driver 1 and driver 2, which its not doing since the remote starter was installed
extreme1
Silver - Posts: 1,070
Posted: December 01, 2004 at 6:43 PM / IP Logged
when it means remote or key it's still based on remote, one adjusts setting as soon as you unlock the doors, the other when you insert the key in the cylinder.
GMDAA does do driver recognition, but the GMDLBP does.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Patel
Copper - Posts: 86
Posted: December 01, 2004 at 7:42 PM / IP Logged
oh ok
so if the guy is not using his factory remotes anymore the car can't tell between the two different keys and there respect drivers
am i in the right track
jrilla
Gold - Posts: 1,498
Posted: December 01, 2004 at 10:28 PM / IP Logged
The car can still recognize the keys, but it will not even try to recognize them if the remote starter has started the car, since the bypass is what is being recognized at the time the engine starts, then the computer doesnt expect a different key to be inserted so it doesn't even check for a different key.
J Rilla
Owner/Installer
extreme1
Posted: December 01, 2004 at 11:18 PM / IP Logged
mmm, the car has no way to tell the difference between the key's, just the RF code the FOB's transmit. I have tryed this with an 03 envoy today.. unlock door with keys and start with key, seats and mirrors do nothing
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Patel
Copper - Posts: 86
Posted: December 02, 2004 at 7:40 AM / IP Logged
thanks guys
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
