DEI 555H bypass in a 99 Acura TL
clsmith
Member - Posts: 34
Posted: December 13, 2004 at 10:28 PM / IP Logged
I'm trying to install a Crimestopper CS2011RS Series IV in a 1999 Acura TL 3.2 along with a DEI 555H imobilizer bypass. The problem I'm having is that none of the keys (including the valet)will "learn". In short: Got everything wired via the directions. Car WILL remote start with key in the cylinder. So with the test passed I installed the bypass. LED comes on. Remote start kicks in but the LED never goes out (the LED should shut off following a successful learn/program.) The vehicle starts fine with just the key. Won't start if I unplug the 555H harness (wiring good?)
Any help would be appreciated.
cls
profuse007
Gold - Posts: 2,015
Posted: December 14, 2004 at 12:00 AM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+ |ignition harness            |
|          STARTER|BLACK/ white        |+ |ignition harness            |
|        IGNITION|BLACK / YELLOW        |+ |ignition harness            |
|        ACCESSORY|yellow              |+ |ignition harness            |
|       POWER LOCK|BLACK/ blue          |- |passenger fuse box *1       |
|     POWER UNLOCK|orange              |- |passenger fuse box *1       |
|       LOCK MOTOR|WHITE/ red           |   |drivers fuse box *2        |
|     UNLOCK MOTOR|yellow              |   |drivers fuse box *2        |
|    DISARM DEFEAT|lt. GREEN/ red       |   |passenger MUX module *3     |
| PARKING LIGHTS +|RED / black           |   |passenger kick panel        |
| PARKING LIGHTS -|RED / yellow          |   |left of steering column     |
|       HEADLIGHTS|blue/red            |- |left of steering column     |
|     DOOR TRIGGER|BLACK/ white        |- |passenger fuse box          |
| TRUNK/HATCH PIN|blue/green          |- |drivers fuse box            |
|        HOOD PIN|yellow              |- |passenger fuse box          |
|TRNK/HTCH RELEASE|WHITE/ red           |+ |passenger MUX module *3     |
| DISARM NO UNLOCK|blue               |- |drivers door key cylinder   |
|       TACHOMETER|blue               |   |drivers shock tower *4      |
|       BRAKE WIRE|WHITE/ black        |+ |brake switch               |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 Located in a green 20-pin connector. Use the key switch in the passenger door to test. *2 Located in a green 18-pin connector. *3 The passengers MUX module is located behind the glove box.    *4 In a 2-pin connector near the air intake on the drivers side shock tower.
not seeing 555H available, you might want to switch over to 555U and give up a spare key.
555H is applicable for 01-02
Houston,TX
hagmanti
Silver - Posts: 304
Posted: December 14, 2004 at 12:36 AM / IP Logged
Actually, profuse007, that's not what you say here.
DEI 555H bypass in a 99 Acura TL -- posted image.
However, I think the chart is wrong-- the 555H's instructions also say 01-02.
Me
clsmith
Member - Posts: 34
Posted: December 14, 2004 at 8:58 AM / IP Logged
Thanks for the replys
I just got off the phone with the store that recommended the 555H. All of a sudden they said it's hit or miss and that since that didn't work I should get a 555U or 556U DEI 555H bypass in a 99 Acura TL -- posted image.. I was REALLY hoping to avoid leaving a key in there.
Another installer said that the keyless bypasses on the Acura's tend to have problems (could've been trying to sell me the 555U though.)
cls
profuse007
Gold - Posts: 2,015
Posted: December 14, 2004 at 11:04 AM / IP Logged
sorry ppl, that chart is some what not acurate. gotta fix it.
Me
Houston,TX
ncxvtguy83
Member - Posts: 10
Posted: December 16, 2004 at 3:02 AM / IP Logged
Hello, I also have a 99 TL.  I'm trying to find the trunk release (WHITE/ red wire)
Can someone please tell me how I can figure out which module is the MUX module?  I know the Mux module is located behind the glove compartment, but what is a mux module.  Thanks in advance.
kgerry
Platinum - Posts: 3,455
Posted: December 16, 2004 at 9:15 AM / IP Logged
some of the Honda bypass just wont learn the key... dont know why but i've seen it before... i always tell my customers that we'll try it with a H or I first, but if neccessary we'll have to use the 555U...... what i do is go to the the local key shop a block or so away from me and get them to code another key but not cut it... then i have a key to use in the 555U but the key could never actually start the car.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
ksingh
Copper - Posts: 62
Posted: December 16, 2004 at 7:54 PM / IP Logged
why dont you guys just wire up a relay and use it saves you the trouble of bying those bypass modules and going through all those problems
i do it all the time never had aproblem  the customer has to give up a key but i usually just grind the key down and wire up a relay and just hook it up to one of ur output wire from the alarm and should work fine
Kenny
