2000 Grand Cherokee key recognition
AutoAcoustics
Member - Posts: 11
Posted: December 14, 2004 at 2:57 PM / IP Logged
okay, 2000 Grand Cherokee, put in a remote start, everything works fine as far as remote starting goes.  The vehicle has the system that recognizes the driver by which key is inserted....seat position, radio memory, climate controls.  That stuff isn't working properly anymore.  It has buttons on the driver door for driver1 and driver2, which seem to be working, but the keys don't work.  My thinking is that while programming the 555c, the keys somehow got deleted from the memory.  Anyone else run into this problem?  I've done several Grand Cherokees around this year model, but its the first I've seen that had the key recognition stuff.  Thanks in advance.
Paul Walker
Auto Acoustics
Hillsborough, NC
Platinum - Posts: 12,488
Posted: December 14, 2004 at 4:08 PM / IP Logged
The 555C isn't intended to retain any of the driver memory functions as this is not a OBDII interface module. If you want to retain driver 1 information you must use a JDL-PK that will retain all driver #1 memory settings as well as other interface options.
extreme1
Silver - Posts: 1,070
Posted: December 14, 2004 at 7:15 PM / IP Logged
yeah, the vehicle uses the remotes to identify driver, not the key.
as Jeff said, JDL-PK will retain driver 1 when used.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
AutoAcoustics
Member - Posts: 11
Posted: December 15, 2004 at 4:04 PM / IP Logged
Yeah, I figured out later on my own that it was the transmitter and not the key that activated the memory functions, as the customer had told me.  I just wired it so the factory transmitters could activate the remote start, now everyone's happy.  Thanks fellas.
Paul Walker
Auto Acoustics
Hillsborough, NC
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
