alarm in oldsmobile 98 touring sedan
mastahjay69
Member - Posts: 6
Posted: December 15, 2004 at 9:06 PM / IP Logged
i'm obviousely a newb and so i have this question. where am i to locate my stock receiver in the car?  i dropped down my glove box and found several small boxes. none have 12 or so wires going to them, mostly only six.  also i found wirering diagrams on this site but they do not include things like my trunk release.  where do i find another diamgram?
Hymer
Silver - Posts: 695
Posted: December 15, 2004 at 9:12 PM / IP Logged
Just leave all the stock stuff alone, you shouldn't have to remove anything.. BTW what is the model of your 98 olds??
mastahjay69
Member - Posts: 6
Posted: December 15, 2004 at 9:17 PM / IP Logged
it's 1990 oldsmobile 98 touring sedan. i need to remove the stock set up so that i can put in the new one using the same wires.
audifive
Copper - Posts: 89
Posted: December 15, 2004 at 10:05 PM / IP Logged
dont remove anything, just tap into the existing wires.  as for the trunk release and other stuff, just go to the location of the switch or button and test the wires with a meter
mastahjay69
Member - Posts: 6
Posted: December 15, 2004 at 10:06 PM / IP Logged
yes but were do i find these wires? i needed to find the original reciever to have all the wires in a central location. from there i can tap into the wires.
audifive
Copper - Posts: 89
Posted: December 15, 2004 at 10:50 PM / IP Logged
you can use the guide on this site to help you find the parking light, headlight, horn trigger, door lock and unlock, starter wire(for a starter kill), and constant 12 to power the unit.  only thing left would be the trunk release, which like i said you can find at the button in the car.  a hood pin you can install yourself if you felt like you needed one for extra security.  you could be halfway done with the install before you find the factory keyless unit and confirm what all the wires are for.
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
