Aftermarket Power Locks
wxxyz
Member - Posts: 20
Posted: October 16, 2002 at 2:55 PM / IP Logged
I have a Toyota 4Runner with manual locks, and I bought some power door locks. I checked the security section, but I just got confused......3, 4, 5 wire? There are 2 wires coming out of the actual lock assembly.....One wire has markings that look like (-) Signs. The other wire is just plain blue. Any ideas?
Thanks in advance!
Ohmz
Copper - Posts: 193
Posted: October 16, 2002 at 3:58 PM / IP Logged
Did you buy a complete set with relays and buttons? If you didn't you will have to use relays to hook the locks up to your security system.
securinu
Silver - Posts: 772
Posted: October 16, 2002 at 5:44 PM / IP Logged
is the other wire green?? if so the follow this diagram.
Aftermarket Power Locks -- posted image.
wxxyz
Member - Posts: 20
Posted: October 17, 2002 at 3:44 PM / IP Logged
Yeah, the other wire is green, Securinu, BUT! :)  I don't have an alarm, I just wanted to hook up power locks.....I'm planning on getting an alarm, but not for a while yet. I guess I will need a relay still, but where do I put the relays in the circuit? And I can't ground the Lock because you have to switch polarity to get it to 'push' or 'pull'  ?
Ohmz....No I didn't...I just bought the actuators?!(the part that actually does the pushing and pulling).
wxxyz
Member - Posts: 20
Posted: October 17, 2002 at 3:45 PM / IP Logged
Another Question: There are no holes in the door or the door jam to run a wire....Any suggestions?
securinu
Silver - Posts: 772
Posted: October 17, 2002 at 9:17 PM / IP Logged
what year 4 runner . you can replace the alarm lock/unlock outputs with a switch.
wxxyz
Member - Posts: 20
Posted: October 17, 2002 at 11:01 PM / IP Logged
It's a 1990 4door.
Sidenote, but also interesting: I got the wiring diagram off this site for the stereo, and its not a match. It says attach the yellow to the (-) of the left rear......there is no yellow wire coming out of the stock stereo!!!! Anyone know where I can get a different color scheme?
wxxyz
Member - Posts: 20
Posted: October 17, 2002 at 11:04 PM / IP Logged
Thanks Securinu....
I reread you're post:
Now I understand what you're saying. I'm gonna give it a try.
wxxyz
Member - Posts: 20
Posted: October 18, 2002 at 12:32 PM / IP Logged
Its a 1990 4runner.
Yeah, I think I'll try that, thanks.
securinu
Silver - Posts: 772
Posted: October 18, 2002 at 1:00 PM / IP Logged
there is a hole in the bottom hinge of the door run thru that hole and drill a hole thru the access hole inside the kick panel. use loom th protect the wires.
