Diode installation
kosoku
Copper - Posts: 76
Posted: December 17, 2004 at 12:46 PM / IP Logged
Ok, this is a noob question, but how do I install a diode? The place I will need one is for my door trigger. I'm handy with a dig. multimeter and soldering iron but never had a need for diodes.
Do you just cut the wire in two, then insert the diode's little wire into each end of the wire, solder and heat shrink it all up?
Anybody got any pictures as opposed to diagrams of how diodes are installed?
Platinum - Posts: 12,488
Posted: December 17, 2004 at 1:52 PM / IP Logged
What are your trying to do here ? It depends on if your trying to block a (-) or a (+) current.  If your using this for door trigger on a Chevy then use this: Diodes
kosoku
Copper - Posts: 76
Posted: December 17, 2004 at 2:33 PM / IP Logged
I'll need to diode isolate the door triggers on my 03 mazda b3000 pickup. I've seen the diagrams on this site before, but I just don't get how to actually wire them in.
griselda
Member - Posts: 41
Posted: December 17, 2004 at 8:16 PM / IP Logged
this diagram is for a negative door triger if you are going to put on a possitive door triger use it the other way ..... go to diagrams on this page and then go to diodes
kosoku
Copper - Posts: 76
Posted: December 17, 2004 at 10:40 PM / IP Logged
Ok, I see that. I've read all of the primers about diodes on this site.
My question is pertaining to the actual connection of the diodes. Do you just solder the tips of them to the end of wires or what? They are so thin it doesn't seem like that would be a strong connection. If I could just see some photos instead of just diagrams I would understand more.
kosoku
Copper - Posts: 76
Mharvey
Copper - Posts: 76
Posted: December 18, 2004 at 6:42 AM / IP Logged
here is another topic oon diodes, it has pictures
https://www.the12volt.com/installbay/forum_posts.asp?tid=32434&KW=DIODES
kosoku
Copper - Posts: 76
Posted: December 18, 2004 at 8:08 AM / IP Logged
Thanks! That was exactly what I was looking for. I don't know why I couldn't come up with that using search.
kosoku
Copper - Posts: 76
Posted: December 18, 2004 at 8:25 AM / IP Logged
So when I am diode isolating door triggers I just put the diode at the splice as shown in the diagram. Cool beans.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
