Viper 790 Responder
LudeBoi
Copper - Posts: 81
Posted: October 17, 2002 at 8:05 AM / IP Logged
Im currently planning to buy a Viper 790 Responder this friday for 250! good deal or not?
well also, i was wondering, if all i have to do is connect the wires and bam im done? or
do i have to do some sort of programming? will i be able to do it myself? thanks in advance!
mobiletoys2002
Gold - Posts: 1,050
Posted: October 17, 2002 at 10:13 AM / IP Logged
great alarm same wiring as the 550 esp same programing for stuff like passive arming, ignition controlled door locks things like that but the install manual will tell you how to program the unit and there is no need for a bitwriter you can use the valet switch to program.. it is the same alarm as the 550 esp with a pager and more range thats it. If you have done remote starts/alarms before it is easy but if it is your first time then yeah it will be a little dificult but if you read this forumn and the install manual a few times and ask questions you should be fine on your own. 250$ is not bad considering all the savings on putting it in yourself . the alarm has about 30 wires which some are not used most of the time. depending on your car, you may need a few relays,diodes,etc that are not included with alarm for locks and other stuff like domelight supervision,trunk pop, etc.. good luck
LudeBoi
Copper - Posts: 81
Posted: October 17, 2002 at 3:48 PM / IP Logged
thanks! i've previously installed a simple prestige in my g/f's car, works fine! so now im stepping up! haha keep an eye out for any questions that I may have please!! thanks a bunch
GheTToBaSS
Member - Posts: 33
Posted: November 17, 2002 at 9:53 PM / IP Logged
where can you get it for $250? I'm also looking at getting one of the new DEI Responder systems, but am trying to find the best deal. I will probably have it professionally installed though. Any suggestions are welcome.
Thanks.
