ford f150 air bag after r/s install
mainormoscoso
Member - Posts: 41
Posted: January 02, 2005 at 5:31 PM / IP Logged
I did a 1998 F-150 everithing works fine but the air bag bulb came on after install,  any body had this problem before? I do remeber disconecting a harness from the fuse block could that had  set the air bag bulb to come on?
Teamrf
Gold - Posts: 1,031
Posted: January 02, 2005 at 7:06 PM / IP Logged
Depending on what harness it was..first try resetting the computer, if that doesn't work go back and check your connections on the remote start...make sure all ignitions, and starters are powered up.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
bigjeep
Member - Posts: 24
Posted: January 03, 2005 at 7:51 AM / IP Logged
you need to check if you gave power to the grey / YELLOW 12 gauge wire in the ign. harness, also did you tie into the blue wire for the horn? that wire runs through the airbag harness from the steering wheel.
mainormoscoso
Member - Posts: 41
Posted: January 03, 2005 at 3:15 PM / IP Logged
I got all the conections ok, i will take it to the dealer and have the computer reset and post the results thanks.
