03 Monte Carlo wiring colors same as 02?
Helf
Member - Posts: 16
Posted: January 03, 2005 at 8:49 AM / IP Logged
I will be doing a remote start today on a 03 Monte Carlo, my question is if the wiring on the 03 is the same as the 02?  The newest diagram I can get my hands on is for an 02.  If someone could verify this or if you have a different diagram that would be great.  Thanks,
Jason
KarTuneMan
Platinum - Posts: 7,056
Posted: January 03, 2005 at 9:00 AM / IP Logged
12volts red  +  ignition harness
Notes: The ignition harness is located far right of the steering column, behind the ignition switch.
Starter yellow  +  ignition harness
Second Starter N/A
Ignition pink  +  ignition harness
Second Ignition green  +  ignition harness
Third Ignition
Accessory orange  +  ignition harness
Second Accessory brown  +  ignition harness
This wire must be powered as an accessory wire. If powered as an 2nd ignition the car will not crank.
Keysense
Power Lock ORANGE / black  -  gray 24 pin plug @ BCM
Notes: Lock requires a negative trigger thru a 470 ohm resistor. Unlock requires a straight negative trigger. MUST use relays.
The BCM (Body Control Module) is located above the brake pedal. It is a plastic box with three plugs that face the firewall.
Can also use Directed 456A interface module.
Power Unlock same wire as power lock
Lock Motor
Notes: Installation of factory keyless upgrade alarm is not recommended on this vehicle because the door lock motor wires rest at approximately 7 volts.
Unlock Motor
Parking Lights+ do not use
Parking Lights- white  -  pink 24 pin plug @ BCM
Notes: The BCM (Body Control Module) is located above the brake pedal. It is a plastic box with three plugs that face the firewall.
Must isolate this wire from the BCM to avoid the service engine soon light. See DirectFax document 1600 for wiring information.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger blue & blue/white  -  gray 16 pin plug @ BCM
Notes: The driver door trigger wire is blue. Blue/white will catch the passenger door. Use both wires and diode isolate each.
Have to also diode isolate from the BCM to prevent false alarms. Refer to DirectFax document 1076 for wiring information.
Dome Supervision use door trigger
Trunk/Hatch Pin RED / black  -  gray 24 pin plug @ BCM
Hood Pin
Trunk/Hatch Release black  -  release switch
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm lt. green  -  gray 16 pin plug @ BCM
Disarm No Unlock see factory alarm disarm
Tachometer white  ac  ignition coil
Wait to start N/A
Brake Wire white  +  brake pedal switch
Parking Brake
Horn Trigger black  -  steering column
Notes: Horn can also be found at a black plug with a blue insert above the gas pedal.
Memory Seat 1
Memory Seat 2
Memory Seat 3
03 Monte Carlo wiring colors same as 02? -- posted image.
Immobilizer Bypass Module:Required: YesType: Passlock 2Part #: 555L or 555T
Tuesday, April 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
