2003 Ram Parking Lights
porkyman
Posted: January 05, 2005 at 9:20 PM / IP Logged
I've been reading the post concerning this problem and I cant find where to solve it. I have an Omega Max Remote Start/Security System and everything is connected right execpt the parking lights. I know I have to use a 330 ohm resister to activate the parking lights but once I press unlock on the remote a min later they come back on. I think you have to use a relay to keep this from happening. Can anyone explain to me how to get this accomplished? and where to get the parts to do so.
Thankyou2003 Ram Parking Lights -- posted image.
actionjackson
Copper - Posts: 59
Posted: January 05, 2005 at 9:39 PM / IP Logged
I always go to the BLACK / YELLOW wire at the headlight, easy to get to, its a (+), no problems
Jamie Jackson
*CRIMPING AINT EASY*
slicksam
Copper - Posts: 291
Posted: January 05, 2005 at 9:43 PM / IP Logged
according to my notes 2004, it is white green, using a relay and a resistor.
so this should be the same
https://img42.exs.cx/img42/4867/dodgeram15002005parklights5em.jpg
Testing is the key
porkyman
Posted: January 05, 2005 at 10:12 PM / IP Logged
howmay amp relay would you reccommend?
Williegz
Posted: January 06, 2005 at 1:29 PM / IP Logged
hey guys, I am doing one and I can not get these door locks to work. Can I get some help with that?
Wm Gonzalez
KarTuneMan
Platinum - Posts: 7,056
Posted: January 06, 2005 at 1:45 PM / IP Logged
The parking light is purple / YELLOW  it needs to be "brken" with the a relay and resistor.
87a gets the switch side of the wire
30 gets the car side of the wire
86 and 87 ground with the resistor in line
85 gets trigger from the alarm or RS
works perfect every time!!
mobileworks
Copper - Posts: 136
Posted: January 06, 2005 at 6:21 PM / IP Logged
Lock Requires A Ground (-) Pulse Through A 867 Ohm Resistor. Unlock Requires A Ground (-) Pulse Through A 364 Ohm Resistor.  Single wire door lock system...
Factory arm and disarm wires will also lock and unlock the doors as well as arm and disarm at the same time, if equipped....requires different resistance values...
Bnluis
Silver - Posts: 578
Posted: January 06, 2005 at 7:35 PM / IP Logged
I use a WHITE/ Grey wire above the Driver kick panel. it is positive no relays required.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
