alarm wiring
wgasca
Member - Posts: 29
Posted: January 09, 2005 at 4:57 PM / IP Logged
I have a 01 honda accord lx sedan and i bought a commando car alarm remote start w/ way pager and i know where all the wiring goes eccept for a couple.
-ground output when running
-connect to a 30 amp relay for starter disable output (-)
if anyone can help me i would appreciate it
thank you
ah64mark
Member - Posts: 8
Posted: January 09, 2005 at 7:22 PM / IP Logged
ground output when running (-) is for a key bypass kit . so you can start your car via remote without a key. if your key has a resister or transponder in it you will need this unit or you will be unable to start you car without a key in the cylinder.  if you can start your car now by remote, no need to worry about this wire. if you cant , put the key in the cylinder and start it with the remote , if it starts you need an external bypass kit.
starter disable output(-) is usually an orange wire from the alarm. you will be able to find out how to wire this with a relay , to the left colum under CAR SECURITY (starter interrupts) you will need an external relay for this application
i hope this helped
ah64mark
dar1
Member - Posts: 23
Posted: January 09, 2005 at 10:41 PM / IP Logged
Exactly. On point with the infomation.......I can't put it any better myself. In short the ground output when running(-)is to interface with remote start bypass . And the starter disable output(-) is for exactly that starter interupt which is to be wired with a relay NO/NC...
one love
wgasca
Member - Posts: 29
Posted: January 09, 2005 at 11:33 PM / IP Logged
so in other words thos 2 wires connect to the bypass module
KarTuneMan
Platinum - Posts: 7,056
Posted: January 09, 2005 at 11:47 PM / IP Logged
Only the ground while running does. The other get wired in to a relay for your starter disable. Look on this site under "relays" for an example of how to do that........
Good luck
KarTuneMan
Posted: January 09, 2005 at 11:48 PM / IP Logged
alarm wiring -- posted image.
dar1
Member - Posts: 23
Posted: January 10, 2005 at 12:40 AM / IP Logged
Hope not confusing you. As you can see thanks  to the KarTuneMan they serve different purposes. Hope everything works out with your install..
one love
Wednesday, September 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
