2005 acura tsx
hanhpham2k
Member - Posts: 15
Posted: January 09, 2005 at 6:48 PM / IP Logged
 Please help me ...I am installing a Clifford rs3.5 to my rsx . I did everything but I'm stuck on how to do the door lock and unlock ...
  Wiring saids : green(-)lock (+)unlock
                              blue)+) unlock (-) lock
    How do I connect these wires do I need a relay and/or do i need to cut any wires in the car lock /unlock ? Please help me . thank you so much
profuse007
Gold - Posts: 2,015
Posted: January 09, 2005 at 8:05 PM / IP Logged
green- lock (-)
bluw- unlock (-)
plug it straight onto the objective wire.
Houston,TX
hanhpham2k
Member - Posts: 15
Posted: January 09, 2005 at 8:36 PM / IP Logged
profuse007 , can you show me how to wire the Dei part#451m so It can roll the window up/down ..thanks
hanhpham2k
Member - Posts: 15
Posted: January 11, 2005 at 9:08 PM / IP Logged
any body knows which is the factory disarm wire in the car besides the one in the door ...thanks alot
misterjimbo
Silver - Posts: 535
Posted: January 12, 2005 at 8:00 AM / IP Logged
you dont want the factory disarm wire in the door? ok use this one... its in the door. it is at the module. dei says its data bus comming in the car so you have to go to the driver door module
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
