commando ez2600 trouble
my71454
Posted: January 09, 2005 at 9:27 PM / IP Logged
I am currently installing a remote start and keyless entry commando ez2600 on my wifes 2003 Kia Spectra , everything is working except the start function , I am getting door lock and unlock , trunk pulse , and 5 pulses for the start funtion but the vehicle is not starting , when i get the pulses (relay clicks) the dash lights dont come on either is this a programming problem or instalation problem? I have gone over the wiring and everything is hooked up correctly , the only wires I didnt use were the pulse to start wires , I was lead to believe that they were only used for theft deterent systems.
ah64mark
Member - Posts: 8
Posted: January 09, 2005 at 10:45 PM / IP Logged
did you hook up the BLACK/ white wire to ground? did you get the tach signal for that vehicle?
ah64mark
jrilla
Gold - Posts: 1,498
Posted: January 10, 2005 at 12:37 AM / IP Logged
I am not aware of a 2600, but I am aware of a 2500. if it is a 2500, then you need to enter programming before the unit will even attempt to remote start. Look in the programming tables where it describes the type of starting: tach monitoring, voltage monitoring or timer.
J Rilla
Owner/Installer
my71454
Posted: January 12, 2005 at 9:55 PM / IP Logged
O. K. I tried the programming and still doesnt work double checked all my current hookups and they are Ok . so I will try this Here is a list of the wires I DO NOT  have hooked up maybe somebody can help . white and red for onepulse to start    white and orange three pulse to start    black and yello for hand brake    black and gray for noise input from engine ( I have the programming set for the timer and smart sense start enable)    orange ground output    gray trunk       black and white dome light output          blue and white passenger unlock output I would appreciate any help you can give me
plinderson
Posted: January 17, 2005 at 11:48 AM / IP Logged
I just installed a 2600.  I found out after three phone calls that two things must be in place.  #1  hood trigger must NOT be grounded (it doesn't need to be hooked up if you choose.  And # 2 which was my problem.  The hand brake wire MUST be grounded.
Finally starting....
Paul
my71454
Posted: January 17, 2005 at 11:11 PM / IP Logged
Paul you were correct it was the handbrake wire that needed to be grounded and thanks everybody for your input, this site ROCKS!!!!!!!!!!!!!
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
