1999 Chrysler T&C alarm
Luweez
Posted: January 16, 2005 at 12:56 PM / IP Logged
Found this site by accident - I'm new, I'm a girl and I want to fix this myself - So...
1999 T&C security alarm is setting off - for no reason.  I've watched (listened?) for a pattern: only when it rains? When it's cold? Windy? Armed keyless? Morning/Night?
Nothing matched and I've tried it all.  All I can figure is it's the sensors.  All I know is I better do something quick (and cheap) before the neighbors kill me.
Thanks in advance for any additional info - I have a print out of  "alarm sensors/triggers" from this site.
Kim --- uh, luweez
KarTuneMan
Platinum - Posts: 7,056
Posted: January 16, 2005 at 1:55 PM / IP Logged
Im assuming its not a factory security system?   If not, did you install the unit? The first thing I would want to do is read the install manual and check all the connections. Also if there are any "programable" options.....make sure they are programmed correctly. Weird things can happen to certain units say, when the battery gets change...check the condition of the battery.
When the alarm goes off, how do you stop it? Is there an LED? most alarms will blink certain number of times to tell you what zone was violated........
Good Luck young lady
Luweez
Posted: January 16, 2005 at 2:10 PM / IP Logged
Yes, sir it IS the factory installed unit... no longer covered under warranty of course
All I know is when I hear it I'm fumbling from a dead sleep most times and turn it off with my remote.
Thanks for the response - see what info I left out.
luweez
hgshoemaker
Posted: January 16, 2005 at 6:01 PM / IP Logged
I had a problem with a customer's T&C, look at the hood switch or better yet unplug the hood switch. This thing would go off randomly unto I pulled it.
KarTuneMan
Posted: January 16, 2005 at 6:05 PM / IP Logged
check your door pins too. Make sure they aren't all rusted up
I dont know what else to tell ya1999 Chrysler T&C  alarm -- posted image.
Luweez
Posted: January 16, 2005 at 10:08 PM / IP Logged
You both gave me good direction and that's what I needed.  Thanks so much!
Tuesday, February 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
