2000 GP auto lock?
homey88
Member - Posts: 42
Posted: January 21, 2005 at 1:58 AM / IP Logged
 After i installed r/s the factory autolock isnt working, any ideas? i have to go back under to hook up the arm and disarm wire for the factory alarm, so what do i look for in regaurds to the autolock. The r/s has this feature but i want to know why the factory one isnt working anymore.
Brian
mo12v
Posted: January 21, 2005 at 3:56 PM / IP Logged
Check your Shifter Switch (if you hooked up Neutral Safety) and your wiring again.  The shifter switch sends a signal to BCM to Lock when taken out of Park.
Be sure you have no disconnected wires and that you used Negative Pulse for Door Locks
MO
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
