2005 Chevy Cargo Van.
dunyamunya
Member - Posts: 10
Posted: January 28, 2005 at 8:21 AM / IP Logged
I am looking for a wiring diagram for 2005 Chevy Cargo Van to install remote start and alarm. Can someone help me and provide information needed?
Thank you in advance,
Andrew.
Andrew
Moderator - Posts: 12,488
Posted: January 28, 2005 at 9:03 AM / IP Logged
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=5909&product=Remote%20Start#
Super easy vehicle to work on. Only hard wire to access is the tach wire.  I used the injector wire instead ( TAN ) at the top of the engine just below the firewall.
dunyamunya
Member - Posts: 10
Posted: January 28, 2005 at 9:52 AM / IP Logged
Thank you, Velocity Motors.
Andrew
Posted: January 28, 2005 at 10:15 AM / IP Logged
One more thing is that you need to use the databus Passlock II bypass module. I tried using the PLZAP ( resistor type module ) and it does work, but the Passlock light stays on. I ended up using the GMBP module for the '05's and it works without errors.
Saturday, November 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
