03 honda accord r/s probs
stang351w
Silver - Posts: 350
Posted: January 31, 2005 at 1:14 PM / IP Logged
hello, i just finished installing a remote start system (as-1414) into a 2003 honda accord, when the doors aint locked and alarm aint set the remote starter works fine, when the alarm is set it sets the alarm off 1 out of 4 times. i looked in the door  for the wires which my paper said (WHITE/ red (arm) white (disarm)  but i could not find those wires inthe door. anyone have any other answers or helpful tips so i don't have to tell the customer to unlock her doors befor she uses the remote starter 03 honda accord r/s probs -- posted image.
Platinum - Posts: 12,488
Posted: January 31, 2005 at 1:26 PM / IP Logged
You have to remove the door panel and the door module is located on the control harness where the window plug is located.
snguyen
Silver - Posts: 281
Posted: January 31, 2005 at 1:51 PM / IP Logged
You will need to drill on the top on the harness inside the door to be able to get the wire though the door.   Make sure you are sure of the placement before you start drilling.
JWorm
Platinum - Posts: 2,208
Posted: January 31, 2005 at 8:28 PM / IP Logged
Or you can order the HODL2 from www.bypasskit.com and have it control lock, arm, unlock, disarm, trunk release, hood pin and door trigger all by connecting to one wire at the fuse box in the drivers kick. Every 03+ Accord EX I do gets a HODL2 and a PKH3 (transponder bypass). Running wires into the door is a pain in the butt on that car.
snguyen
Silver - Posts: 281
Posted: January 31, 2005 at 9:03 PM / IP Logged
JWorn is right that you can get the HODL2...but on couple of time I had to still go into the door.
stang351w
Silver - Posts: 350
Posted: February 01, 2005 at 6:34 AM / IP Logged
if it was my own shop or a deicent shop it would get the hodl2, but the owner's to cheap to do things properly,  but i guess i can't complain to much...it's a paycheck till i find something better 03 honda accord r/s probs -- posted image.
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
