viper LED w/ultra start?
mikk
Member - Posts: 35
Posted: February 01, 2005 at 11:27 PM / IP Logged
i'm installing a ultra start 4255 and wonder if theres away to hook up the led from the viper to it. i know the antenna has the led on the ultra. wonder if additional led is possible to use also?
mikk
thepencil
Gold - Posts: 1,526
Posted: February 02, 2005 at 8:27 AM / IP Logged
You can hook up as many LED as heart desired if you run a relay to power them up. The only caution you have to take is to make sure that the LED you are using is rated for 12V as some LED that comes with the alarm unit can only handle 3 to 4 volts. If you connect them to a 12V power supply you will end up burning them.
Be careful whose advice you buy, but be patient with those who supply it.viper LED w/ultra start? -- posted image.
mikk
Member - Posts: 35
Posted: February 02, 2005 at 8:40 AM / IP Logged
oh i see- what wire would you have to tap into to on ultra start to add led?
mikk
thepencil
Gold - Posts: 1,526
Posted: February 02, 2005 at 8:46 AM / IP Logged
Stater Kill Wire is one of the wire you can use.
mikk
Member - Posts: 35
Posted: February 02, 2005 at 9:50 AM / IP Logged
ok, thanks. so i just have to install relay between the two. ?
mikk
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
