Door Locks on 97 Mitsu Diamante
zanthius
Member - Posts: 7
Posted: February 10, 2005 at 12:54 PM / IP Logged
Hey guys and gals.
I'm in the process of installing a BullDog RSA112 system.  The remote start works well.  However, I am having problems with the door locks.  I could not find any wires listed in the Wiring Chart.  So I probed around and found 2 wires behind the switch.  They both go to the actuator, then they change color afterwards.  Anyways, I got the Lock to work, but the Unlock only unlocks the Driver door; not the rest.  I think the wires are ONLY to the driver door actuator.  Where are the other wires to the rest of the car???
Also, I found a pair of wires that are GND and goes +12V when lock and unlock are applied.  But applying +12V to these does nothing.
I am so lost...  If anyone installed on this car, plz lemme know what wires i need for unlock!Door Locks on 97 Mitsu Diamante -- posted image.
Thanx..
thepencil
Gold - Posts: 1,526
Posted: February 10, 2005 at 2:00 PM / IP Logged
You need to program the unit to a double pulse.
MITSUBISHI, DIAMANTE, 1997, Power Unlock
A single pulse unlocks just the drivers door, and a double pulse will unlock all of the doors.
Power Lock blue    -   in drivers door
Power Unlock RED / green    -   in drivers door
Be careful whose advice you buy, but be patient with those who supply it.Door Locks on 97 Mitsu Diamante -- posted image.
zanthius
Member - Posts: 7
Posted: February 10, 2005 at 3:09 PM / IP Logged
Thanks, I appreciate it.
Yep....those were the wires i used......theres no programming instructions for double pulse...just longer duration.....I contacted bulldog.  they havent responded.  anyone know if theres any wire that doesnt require double pulse?
madBedex
Member - Posts: 17
Posted: February 10, 2005 at 4:51 PM / IP Logged
            Hi!
             Go  to  any  car'stereo store and buy a double pulse unlock module,
            it  will  do  the  job no doubt. No  programming  is required. So,just
            hook on,that's it.
madbedex
zanthius
Member - Posts: 7
Posted: February 11, 2005 at 12:51 PM / IP Logged
thanks....i finally got a hold of bulldog. that model does not do double pulse...so i'll just wire some relays and cap to do it...thanks again...
