DEI alarm goes off on its own
sexyvic1
Copper - Posts: 144
Posted: February 16, 2005 at 1:59 PM / IP Logged
please help.  please read tot he end, the alram is giving me 2 problems. thank you guys for your time
i have the sidewinder 6500esp alarm.  it has the 4 button remote and the remote start. it is installed in a 1996 grand cherokee
what happens is for a while now the siren of the alarm sounds when it feels like it, most of the time just the lights and stuff would flash to indicate the alarm was going off. once in a while the siren would go off too.
i did have the person who put the alarm in install airhorns in addition to the siren with a relay.
everything worked fine for a year / then the problem with the siren not working properly began.
now , like 2 days ago the sire and alarm just start going off on their own. i know no one hit it because it hapened in front of my face.
the alarm will go off for like 15-30 seconds then shut off, then like 3-5minutes later it would happen again. please help. :(
trunkstare
Member - Posts: 6
Posted: February 17, 2005 at 4:04 PM / IP Logged
I would begin by checking all wiring connections, solder joints if any...checking for cold solders, and I would especially check the grounding of the alarm and the siren. let me know.
Platinum - Posts: 12,488
Posted: February 17, 2005 at 5:24 PM / IP Logged
Usually, DEI products have a diagnostics flash back to tell you what the problem is or what sensor was triggered. Did you do a disgnostics on the system ?
dare_ds69
Silver - Posts: 419
Posted: February 18, 2005 at 6:29 AM / IP Logged
check the ground first, maybe is the battery or hood pin. or check the diagnostic as velocity motors said
how own your mind, control your life.
MECP certified. always use a DMM
sexyvic1
Copper - Posts: 144
Posted: February 19, 2005 at 1:10 PM / IP Logged
whats up guys
i checked all the wireing and everything is fine. the ground was solid.
i spoke to the dei tech and he said the brain is under warranty for life, so he said to just send it back and they will take care of the problem
i hope everything is ok when i get it back.  thanks for your input, i will let u guys know what happens when i get it back.
sexyvic1
Copper - Posts: 144
whats up guys
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
