96 Voyager Factory Alarm Interfacing
Komobu
Copper - Posts: 70
Posted: February 27, 2005 at 5:59 AM / IP Logged
Hi;
I am installing a Autopage rs855 on a plymouth voyager. There is a wire coming off the autopage unit to disable the factory alarm during starting. I have read the code sheets and I haven't seen anything refering to this wire. Could you please help me out and tell me what wire this is and where I can find it? Thanks for any help
Pat
boomer_106
Silver - Posts: 710
Posted: February 27, 2005 at 11:02 AM / IP Logged
Plymouth
Voyager
1996-2000
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
PINK/BLACK, RED & PINK
IGNITION SWITCH HARNESS
OEM Alarm Disarm:
WHITE/ RED (-)
IN DRIVER KICK PANEL *****
Dome  Lights/Superv:
BROWN / L GREEN (-)
GRAY # PIN CONNECTOR AT FUSE BLOCK***
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
WHITE/ D GREEN
BLACK # PIN CONN. IN DR. KICK ****
Power  Unlock:
SINGLE WIRE SYSTEM
Trunk  Release:
N/A
Alarm  Input Wire:
BROWN / L GREEN (-)
Notes:
See Note #211 - Chyrsler/Dodge Mini Van Single Wire Door Locks Diagram. ***** Wire Located at BCM in Connector Closest to the Kick Panel; A Negative Pulse Through A 665 Ohm ResistorDisarm and Unlock the Doors and A Negative Pulse Through A 4020 Ohm Resistor Will Arm and Lock the Doors.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
