Chevy Equinox & Cobalt Wire Codes
carguy411
Silver - Posts: 683
Posted: February 28, 2005 at 12:25 AM / IP Logged
just need the alarm wire codes for the 2005 Equinox & Cobalt
i kind of seen 2 things about the equinox was first it says aboutthe factory alarm i think it only arma and disarms with the factory remote which means it wont interfre wit hthe new alarm right??
also i heard theres no need for the starter wire, now how would u go about putting in the starter intreupt relay?
thanks for your help guys
boomer_106
Silver - Posts: 710
Posted: February 28, 2005 at 12:52 AM / IP Logged
Chevrolet
Equinox
2005
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
not used for remote start
Ignition  #1:
Pink +
Ignition switch harness
Ignition #2:
Orange +
Ignition  #3:
n/a
Accessory:
Brown +
Brake  Light:
Lt.Blue +
Brake pedal switch
Tach  Signal:
Purple ac
PCM black plug
Parking Lights:
Brown +
BCM Gray plug
Headlights:
N/a
Diesel  Glow Plug:
N/a
Clutch  Bypass Wire:
n/a
Notes:
 * Please use a vehicle bypass module part number 23571 PLXR. To bypass the passlock and the starter wire on the vehicle.
Chevrolet
Equinox
2005
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED / white +
OEM Alarm Disarm:
Fatory remote only
Must use factory remote to disarm alarm
Dome  Lights/Superv:
OEM Horn:
Tan -
BCM Pink plug
Power  Lock:
Lt.blue +
BCM pin B4 pink plug
Power  Unlock:
Dk.blue +
BCM pin A3 In gray plug
Trunk  Release:
Alarm  Input Wire:
Notes:
boomer_106
Silver - Posts: 710
Posted: February 28, 2005 at 12:54 AM / IP Logged
Platinum - Posts: 12,488
Posted: February 28, 2005 at 10:43 AM / IP Logged
The new GM's/Pontiac/ Chevy's that do not have a starter wire will not require a starter disable relay because you can not grind the starter. You can sit in the car and start it, but leave the key in the start position forever ( if you want ) and it will never grind the starter because the starter circuit is activated after the power drop from the accessory circuit. This is great cause you never have to install another relay for starter disable into those newer GM's. You will need a bypass module that will integrate into the ignition system , I use the PLXR ( newst veriosn of D7 required ) and it takes care of everything. It's a great module and works like a champ ( just make sure you have the newest S, H & D on the modules ).
carguy411
Silver - Posts: 683
Posted: March 01, 2005 at 9:25 AM / IP Logged
i would only need the bypass module for a remote start not for a naormal alarm keyless entry install right?
and i think botho of these from looking at the wire codes should be a easy straight foward install anything i should look out for
Posted: March 01, 2005 at 10:32 AM / IP Logged
The bypass module is not necessary for security only systems. The only problem you might have is the unlocking/disarming of the OEM security system. If it's anything like the Pursuit that I worked on, the only way to disarm the OEM system is with the OEM remote control or remove the programming from the vehicle.
carguy411
Silver - Posts: 683
Posted: March 01, 2005 at 1:50 PM / IP Logged
how yould you go about doing that and on which car is that anyone else have this problem???
theres no oem disarm wire or anything?
carguy411
Silver - Posts: 683
Posted: March 04, 2005 at 9:48 AM / IP Logged
has anyone figured out how to disarm the factory alarm on the cobalt. i dont want to have to make them use 2 diff alarm remotes thats kind of points less.
i noticed on the equinox that the factory alarm only arms and disarms with the facroty remote so if we dont use it at all then theres no problem. the cobalt isnt the same way.
please let me know if anyone found out anything thanks
Monday, March 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
