Is The Siren My Problem?
justacar
Member - Posts: 8
Posted: February 28, 2005 at 8:59 PM / IP Logged
Hi
  I have a Code Alarm CA-645 installed on my car. Now, my problem is that the siren will go off when i open a door...etc. It just dosent sound when i arm/disarm the alarm, and theres like no sensitivity to it( i basically need to kick the car for it to go off). Do i need a new siren or is it something else. Please help!!!! Thanks In Advance!!!!
gcorrea
Silver - Posts: 436
Posted: February 28, 2005 at 9:59 PM / IP Logged
you might need to program the arm and disarm chirps to the on position.
gcorrea
bretbowman
Copper - Posts: 156
Posted: March 01, 2005 at 1:24 AM / IP Logged
This is usually why people pay bigger bucks for systems like Clifford and some higher end Vipers because the "sensors" really MAKE the alarm system.  The Clifford systems come with Omnisensors as the primary shock sensor and they are incredibly sensative.  You can adjust the sensitivity, of course, but they have the ability to be very sensitive if you set them so.
You just don't get this on lower end alarms.  You can try adjusting the sensitivity, assuming that you have that option on the Code alarm (not as familiar with that brand).
Good luck!
2002 Toyota Sequoia Limited 2WD (Clifford G5 Avantguard 5 w/ 2 SmartWindows modules) - IT Engineer - NRA Life Member - LDS Return Missionary - Married for time AND ETERNITY - Eternally sealed family
dare_ds69
Silver - Posts: 419
Posted: March 01, 2005 at 7:09 AM / IP Logged
you can adjust the sensitivity of the shock sensor, and try to program the alarm read the instructions .
how own your mind, control your life.
MECP certified. always use a DMM
justacar
Member - Posts: 8
Posted: March 01, 2005 at 12:34 PM / IP Logged
the instructions dont say anything about shock sensors or how to adjust the sensitivity. whats really bothering me is that the siren dosent sound when i arm/disarm the car, only when a door/hood...etc is opened. This is the main problem i want to get fixed.
justacar
Member - Posts: 8
Posted: March 01, 2005 at 12:35 PM / IP Logged
the instructions dont say anything about shock sensors or how to adjust the sensitivity. Where would the typical places i should look for the shock sensor? whats really bothering me is that the siren dosent sound when i arm/disarm the car, only when a door/hood...etc is opened. This is the main problem i want to get fixed.
Hornshockey
Silver - Posts: 520
Posted: March 01, 2005 at 3:18 PM / IP Logged
Everything is included in the brain for that alarm, there is no external shock sensor.  As for programming the shock sensor; and the arm/disarm chirps, if you had it installed at CC take it back there, the shock sensor programming is a 5 minute job or less, and the arm/disarm chirps can be activated with the RF progammer in a snap.
To adjust the shock sensor yourself
with the driver door openturn key to run postion, within 10 sec push and hold valet overerride switch until alarm sounds, you will hear 3 chirps, this is the transmitter programming mode(if you have any extra remotes to program, now would be the time).  Push and realease the valet button 2 more times until you hear 5 chirps, this is the shock sensor programming.  Push the opt button on your remote and you will hear the alarm sound one chirp, this is the primary or warn-away sensor programming, push your lock button to increase sensitivity and unlock to decrease.  Push the opt button again, the alarm will sound twice, this is the full trigger sensitivity mode, again lock/unlock to increase/decrease, turn the key off when done and test your new settings, you'll probably have to repeat a few times to get it right where you want it; I usually do.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
swamprat323
Gold - Posts: 1,335
Posted: March 01, 2005 at 6:09 PM / IP Logged
Hit arm or disarm twice to have the chirps. It set to silent chrips.
justacar
Member - Posts: 8
Posted: March 02, 2005 at 3:52 AM / IP Logged
thanks for the info everyone, hornshockey im going to try that first thing tomorrow and see if it does anything. could u tell me how to activate the disarm and arm chirps myself? Again thanks
Hornshockey
Silver - Posts: 520
Posted: March 02, 2005 at 4:42 AM / IP Logged
sure; to activate arm/disarm chirps:
turn ignition on then off
within 10 sec push and release valet override button 3 times
1 chirp confirms chirps enabled / 2 chirps confirms chirps disabled
hope this helps!
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
