Checking Door Lock Actuators?
dj styles
Member - Posts: 14
Posted: November 06, 2002 at 9:25 AM / IP Logged
some one help please, im in the middle of an install and need to check the actuators on the door locks to see if they work. how can i do this without damaging them if they do work. thank in advance.
gabriel correa
the12volt
Administrator - Posts: 3,959
Posted: November 06, 2002 at 11:28 AM / IP Logged
Are these factory installed actuators or aftermarket actuators? What vehicle are these in? Typically the actuators will have two wires going to each, however some may have more. If they have two wires going to each, at each actuator, disconnect the leads going into the vehicle and connect 12V+ to one lead of the actuator and momentarily connect ground to the other, the actuator should move in one direction (lock or unlock). Reverse polarity to move in the other direction.
Let us know what you have and what you find.
dj styles
Member - Posts: 14
Posted: November 06, 2002 at 12:12 PM / IP Logged
after market, installed them hooked up the relays and nothing happens. i can hear the relays click but the actuator does not move at all .thank you for you reply.
gabriel correa
go2pac
Copper - Posts: 179
Posted: November 06, 2002 at 3:24 PM / IP Logged
aftermarket...sounds like you did not wire 87a of both relays to ground or you totally miswired the relays.
Karl
Pacific Accessory Corporation
Mobile Audio Interfacing Equipment
Connecting You to Your Music Since 1976
dj styles
Member - Posts: 14
Posted: November 06, 2002 at 5:51 PM / IP Logged
got them working, it was the plug that goes into the alarm that didnt match the relays. thanks everyone.
gabriel correa
