2 stage shock sensor
spl/luxy
Member - Posts: 25
Posted: March 11, 2005 at 6:49 PM / IP Logged
{TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" UNABLE="on"}{TR height="100%" UNABLE="on" width="100%"}{TD id=HB_Focus_Element vAlign=top width="100%" background=""0 UNABLE="off"}{p}I have a Cyclops Alarm installed in my vehicle and i would like some information on the following:{/p}{p}Cyclops has Auxllary input for optional sensor (as above){/p}{p}I would like to add a 2 stage shock sensor onto it, the wiring for the sensor (Autowatch) states to wire as follows: {/p}{p}Red- +12v.. Easy one that {/p}{p}Black- ground - almost easy..{/p}{p}Blue -Trigger, this is where i get a bit messed up,{/p}{p}green - Warning,  should i join the green and blue together using a diode and then connect to the alarm trigger? if this isnt correct what should i be doing to get this to work?{/p}{/TD}{/TR}{/TABLE}{div style="width:240px;border-bottom:1px solid #eeeeee;margin-top:10px;margin-bottom:0px;"}{/div}{span style="font-size:.70em;line-height:1.2em;color:#000000;"}Australia's Loudest Street Max 3-4 Car Ever!{/span}
Platinum - Posts: 12,488
Posted: March 11, 2005 at 6:59 PM / IP Logged
Here is what you should do: http://www.velocitymotorsport.com/images/install_notes/155.jpg
spl/luxy
Member - Posts: 25
Posted: March 11, 2005 at 7:27 PM / IP Logged
oh ok that is kind of what i thought, but this would mean that i would require 2 inputs to the alarm?  or can i just use diodes on the one input?
thanks heaps for the help .... Dale
gcorrea
Silver - Posts: 436
Posted: March 12, 2005 at 12:26 AM / IP Logged
seperate inputs, one for the first stage and one for the second stage. only on dei products can you use only one input, because of the multiplex inputs.
gcorrea
