Alarm arms and then goes off
Craiger22
Member - Posts: 10
Posted: March 24, 2005 at 11:44 PM / IP Logged
I recently installed a crimestopper alarm. It worked right for a day but now when you arm it it starts going off after about 15 seconds. Any help will be greatly apreciated.
nava94
Silver - Posts: 296
Posted: March 24, 2005 at 11:53 PM / IP Logged
 more information is what we need for us to help you. first off what's the cars year, make, model?
Craiger22
Member - Posts: 10
Posted: March 24, 2005 at 11:57 PM / IP Logged
it is a 97 jeep wrangler, the alarm has sensors for the doors and hood, and it also has a dual stage shock sensor
nava94
Silver - Posts: 296
Posted: March 25, 2005 at 12:36 AM / IP Logged
did you double check your wiring with a digital multimeter. correct 12volts, ignition, door trigger, parking lights, etc. did you install a hood pin? does the jeep have a factory alam?
Craiger22
Member - Posts: 10
Posted: March 25, 2005 at 12:53 AM / IP Logged
I did not check my conections because it started out working fine, there was no factory alarm to my knowledge, and no i did not install a hood pin, i used the factory positive pin and added a relay to it as it stated in the manual
Craiger22
Member - Posts: 10
Posted: March 25, 2005 at 2:04 AM / IP Logged
Ok i found the problem, it was my satellite radio, it wasnt turning completely off and it waa drawing too much current and setting off the alrm. Thanks for all the help.
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
