Negative Pulse
bigslammy
Member - Posts: 10
Posted: April 01, 2005 at 10:01 PM / IP Logged
I have to wire something with a neg pulse from my alarm I dont know what this means. Can someone explain and it be simple. Im trying to disarm a F150 97 year factory alarm thanks
Platinum - Posts: 12,488
Posted: April 01, 2005 at 10:11 PM / IP Logged
This means that you need to find a wire that has a 200 - 250 mA negative output on the alarm. Most of the time it will be a trunk release output, AUX channel output or depending on the application it could be the starter disable output.
bretbowman
Copper - Posts: 156
Posted: April 09, 2005 at 5:21 AM / IP Logged
If you want to indefinitely disarm the factory alarm, you can GROUND the factory alarm DISARM wire.  As long as it is grounded the factory alarm should be disabled.  Once you remove ground from this wire, the factory alarm will become active again.
Good Luck!
2002 Toyota Sequoia Limited 2WD (Clifford G5 Avantguard 5 w/ 2 SmartWindows modules) - IT Engineer - NRA Life Member - LDS Return Missionary - Married for time AND ETERNITY - Eternally sealed family
