2005 Nissan Titan King Cab Remote start
Sound Pressure
Silver - Posts: 711
Posted: April 04, 2005 at 2:39 AM / IP Logged
I'm planning on doing a viper 550 on a 2005 nissan titan and was wondering if there is a transponder on this, if so how to bypass it. I read somewhere that just by unlocking it will turn it off but does it not have a chip(resistor) in the key? Thanks for the help everyone!
Sound Pressure
CCroadshoptn
Copper - Posts: 67
Posted: April 05, 2005 at 3:56 AM / IP Logged
12volts
2005 Nissan Titan King Cab Remote start -- posted image.
green (40A)
ignition harness
Starterbrown + ignition harness
Second Starterlt. green or blue/green + ignition harness
IgnitionBLACK/ red + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessoryred + ignition harness
Second Accessorypurple + ignition harness
KeysenseRED / blue to BLACK/ red + ign harn or BCM R of column, pin 37
Power Lockblue - driver door module in door
Power Unlockred (double pulse) - driver door module in door
Lock Motorpurple 5wiBCM to right of column, pin 65
Unlock Motorgreen 5wiBCM to right of column, pin 59
Parking Lights+RED / blue + dimmer switch on dash
Parking Lights-N/A
HazardsWHITE/ black - BCM to right of column, pin 29
Turn Signal(L)GREEN/ black + BCM to right of column, pin 60
Turn Signal(R)GREEN/ YELLOW + BCM to right of column, pin 61
Reverse LightGREEN / WHITE + inside rearview mirror
Door Triggersee notes - BCM to right of column 2005 Nissan Titan King Cab Remote start -- posted image.
Dome Supervisionblue - BCM to right of column, pin 63 2005 Nissan Titan King Cab Remote start -- posted image.
Trunk/Hatch PinN/A
Hood PinN/A
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Armarms with lock
Factory Alarm Disarmdisarms with unlock
Disarm No Unlocksingle pulse power unlock wire
TachometerNOT WHITE/ blue or black ac any ignition coil
Wait to startN/A
Brake WireRED / green or RED / black + brake pedal switch
Parking Brakegreen - parking brake switch or cluster
Horn TriggerRED / white - horn switch
Memory Seat 1lt. GREEN/ black - memory mod. left of column, pin 9
Memory Seat 2pink/blue - memory mod. left of column, pin 25
Memory Seat 3N/A -
Mecp Certified
Double check advice with your Meter.
ken984
Copper - Posts: 78
Posted: April 05, 2005 at 10:11 AM / IP Logged
The online DEI info doesnt show a bypass module as necessary but the download directwire says either a 556U or a 555U. I would be surprised if it didnt require a module.
Platinum - Posts: 12,488
Posted: April 05, 2005 at 12:02 PM / IP Logged
It requires a universal bypass module for the Immobilizer system in the key. Unlock will disarm OEMalarm but not disable Immobilizer.
Sound Pressure
Silver - Posts: 711
Posted: April 06, 2005 at 11:51 PM / IP Logged
Does the universal bypasss require a key? I also have a brain fart question? Bare with me but what is the keysense RED / blue to balck/red wire used for?
Thanks,
Sound Pressure
ken984
Copper - Posts: 78
Posted: April 07, 2005 at 8:14 AM / IP Logged
The 556U does require a key, DEI lists 2 other bypass modules the 555U and the 555H but i do not see either of them in the latest catalog. Bypasskitsdotcom may have something that doesnt require a key. I would check there also.
