530t, viper 791xv
c0ckeyed00
Copper - Posts: 61
Posted: April 11, 2005 at 3:24 AM / IP Logged
is channel 2 the wire everyone uses for this module? in the install guide for th 791xv it says that channel 2 RED / white will, when pressed for more than 1.5 sec, supply an output as long transmission continues. the 530t install guide says, press and release the aux button to vent and hold down for 3 seconds to roll windows all the way to(which means 2 seperate outputs). to my understanding, the channel 2 only gives a single output.   and how do you roll the windows back up after rolling them down when armed?
bretbowman
Copper - Posts: 156
Posted: April 11, 2005 at 4:01 AM / IP Logged
The aux output will pulse unless you hold it, in which case it will offer continuous output until you release the button.  You only need ONE aux output to operate the 530T.  This is a feature of the window module.  If the 530T receives a pulse input on the aux input wire, it will vent the windows, and if it receives more than a pulse, it will (on it's own) procede to roll the windows all the way down.  I believe that you CAN continue to pulse the windows by tapping the button over and over (increasing the vent opening of the windows), but if you hold the button down for more than approx. 2 seconds, the 530T is going to receive that as a "roll down" command and drop the windows completely.
Long story short:   It all works on ONE aux and your "ground when armed" output to roll up/down windows.
This works the same on my Avital Avistart 6500 with 2x 530T Window modules.
2002 Toyota Sequoia Limited 2WD (Clifford G5 Avantguard 5 w/ 2 SmartWindows modules) - IT Engineer - NRA Life Member - LDS Return Missionary - Married for time AND ETERNITY - Eternally sealed family
c0ckeyed00
Copper - Posts: 61
Posted: April 11, 2005 at 11:40 AM / IP Logged
so i can use the RED / white(channel 2) wire for the windows?
nava94
Silver - Posts: 296
Posted: April 12, 2005 at 12:01 AM / IP Logged
ding ding ding, tell him what he won bretbowman! In plain English: Yes, Spanish:Si, Ebonix: Damn Strait. juzt messing maaaaan, yes you can use the RED / white output wire from the alarm to the RED / white input wire of the 530t.yeeaah booi!
Captanham
Silver - Posts: 365
Posted: April 12, 2005 at 1:07 AM / IP Logged
yea, the 1.5 second delay on the viper output just means that to crack your windows or stop them from rolling up just hold it down for 1.5 or 2 seconds, and if you want to roll them all the way down, just hold it down for around 4 or 5 seconds,, my omega has a 2.5 second delay, but it still works, you just gotta hold it down for a second or two instead of just pushing and releasing
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
c0ckeyed00
Copper - Posts: 61
Posted: April 12, 2005 at 11:11 PM / IP Logged
YES!!!! you guys are genius!!! thanks
c0ckeyed00
Copper - Posts: 61
Posted: April 16, 2005 at 1:46 AM / IP Logged
one more question....how do you program channel.. i was reading about channel 4 on my alarm and it says something about being latched(that mean always on right?) i wanted to know how to program it.
thanks
eurotek
Copper - Posts: 58
Posted: April 16, 2005 at 8:21 PM / IP Logged
it tells u in the manual,
c0ckeyed00
Copper - Posts: 61
Posted: April 18, 2005 at 1:18 PM / IP Logged
okay very last one....how do you arm the alarm without rolling up the windows. i says press the aux and within 5 sec. arm the alarm. when i press aux and arm, it rolls the windows up,  on my 791xv pressing aux then arm does a silent one so you don't hear the arm/disarm chirps.
Captanham
Silver - Posts: 365
Posted: April 18, 2005 at 8:20 PM / IP Logged
well because you have that delay on it, you don't press it and then arm it, you'll have to hold it down for that 1.5 seconds or whatever and then arm it, this part is were it gets a little tricky, cause if you hold it down for too long it wont work
Bad Boys Customs
