2000 Ford Explorer Diagram please
Alpine Guy
Platinum - Posts: 2,478
Posted: April 20, 2005 at 2:02 PM / IP Logged
I did a search and could not find a diagram for a 2000 Explorer.  Could someone please post up one or a link to where i can get my future diagrams.
Alpine Guy
the12volt
Administrator - Posts: 3,957
thepencil
Gold - Posts: 1,526
Posted: April 20, 2005 at 3:35 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / EXPLORER / 2000 / Remote Start
12volts yellow    +   ignition harness
Starter RED / lt. blue    +   ignition harness
Second Starter
Ignition GREEN/ purple    +   ignition harness
Notes: Two wires each at switch, both are common, only need to power 1 each during remote start.
Second Ignition
Third Ignition
Accessory gray / YELLOW    +   ignition harness
Second Accessory BLACK/ green    +   ignition harness
Keysense
Power Lock pink / YELLOW    -   driver kick panel
Power Unlock pink/green    -   driver kick panel
Lock Motor pink/black      driver kick panel
Unlock Motor RED / orange      driver kick panel
Parking Lights+ PURPLE / white      driver kick panel
Notes: Also found to be WHITE/ black at the rear of the switch.
Parking Lights- WHITE/ purple      driver kick panel
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      -
Notes: In the drivers door harness find yellow/black for the drivers door. In the drivers kick panel find lt. GREEN/ YELLOW for the drivers rear door. In the passengers kick panel find gray/red for the passenger front door, and pink/lt. blue for the passengers rear door. All four wires are negative trigger and must be diode isolated together. Refer to directfax document #1076 for wiring information.
Dome Supervision use door trigger
Trunk/Hatch Pin WHITE/ purple    -   driver kick panel
Hood Pin tan/lt.green    -   driver kick panel
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms on lock
Notes: Arms on lock only with door open. It is necessary to send a signal to door trigger as well as lock to arm factory alarm.
Factory Alarm Disarm dk. GREEN/ purple    -   driver kick panel
Disarm No Unlock
Tachometer tan / YELLOW      PCM
Notes: The PCM is located at the top of the firewall towards the passenger side, the tan / YELLOW tach wire is also found at the back of the instrument cluster.
Wait to start
Brake Wire lt.green    +   driver kick panel
Parking Brake
Horn Trigger yellow/lt. green    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: PATS Part #: 555P, 555F, 556U, or 555U
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.2000 Ford Explorer Diagram please -- posted image.
Wednesday, September 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
