viper 791XV on mercedes
Markland556
Copper - Posts: 75
Posted: April 30, 2005 at 2:08 PM / IP Logged
ok, i got a Mercedes 300E 86' and im gunna get a Viper 791XV and i had a few questions. How is it gunna work with my air locks? How can i protect my trunk?
nava94
Silver - Posts: 296
Posted: May 01, 2005 at 1:10 AM / IP Logged
check out the diagrams on the left for the relay set up to connect to the vacuum door locks on benz.should be able to get the wires at the driver kick or at the vacuum pump.let us know how it went.
Moderator - Posts: 12,488
Posted: May 01, 2005 at 10:28 AM / IP Logged
TRUNK/HATCH PIN-------------BLACK / YELLOW---------------| - |located at trunk light or alarm
The lock wires are located at either kick panel. Blue wire located in 1/4 inch blk rubber tube with RED / wht and brown wires coming out of drivers door. Passenger side same except trigger wire is green. Pump located under rear seat on passenger side. You have to use a type E system : http://www.velocitymotorsport.com/images/install_notes/E.jpg
Sunday, September 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
