Window Modules, 2005 Avalanche
1rstClassSC
Member - Posts: 21
Posted: May 10, 2005 at 10:50 PM / IP Logged
I am installing a 2 529T's on a 2005 Avalanche. None of the windows go up, and the weird part is that the two rear windows dont respond at all. I had cut the blue wires at the rear window switches and ran 2 pairs of wires to the module's (one from each rear door), then I conected back the blue wires in each door to how they originaly were and now the rear windows dont respond at all. Ive been frantically looking for the fuses for the rear windows but I cant find them in either fuse box (drivers side and hood). Any Ideas as to what might be the problem? Im hopeing I blew a fuse and not the Window motors.
Platinum - Posts: 12,488
Posted: May 10, 2005 at 11:12 PM / IP Logged
Hope you wired in the BLUE H 1/3 & the GREEN h 1/2 to the motor side of the wire and not the switch side otherwise you would have given the swithc 12 volts which would have burned out the switch.
1rstClassSC
Member - Posts: 21
Posted: May 11, 2005 at 1:05 AM / IP Logged
Just in case i did, would that have burned out the switch or the window motor?
How can I test to see if I burned out the switch?
Luis.
mo12v
Posted: May 11, 2005 at 9:13 AM / IP Logged
Meter it........Smell it.........Take off what U installed and rewire back to factory
MO
1rstClassSC
Member - Posts: 21
Posted: May 11, 2005 at 10:05 AM / IP Logged
It smells OK. I rewired it back to factory and It is still not working. The funny part is that the RR window I never connected it to the window module and it still doesnt work. Thats why I think it might be a fuse somewhare that I cant find.
Luis
accord78
Copper - Posts: 97
Posted: May 12, 2005 at 12:03 AM / IP Logged
check your fuses they might of poped!!!!! then try to wire back to factory and cross your fingers u didn't fry something else lol
