bypassing alarm, 1992 Nissan Pathfinder
brwski
Posted: May 17, 2005 at 2:56 PM / IP Logged
i need help - the vehicle i am trying to get into running order
(1992 Nissan Pathfinder SE) has been stored for several months. After removing/charging and reinstalling the battery - i cannot get it to start - the alarm seems to be overriding the ignition - all lights go on, windows open, doors lock and the car won't start. the only identifying marks i can find are on the relay under the hood next to the "siren/horn" device and it says
"PRO 9094C"
if anyone can identify this system from that information and tell me how i can bypass it (if possible) i would appreciate the information as i need to get this beast on the road.
thanks,
brwski
Powermyster
Silver - Posts: 962
Posted: May 17, 2005 at 3:49 PM / IP Logged
go to the ignition switch and trace the starter wire see if its chopped anywhere for a starter kill.
has it got an alarm on it?
brwski
Posted: May 17, 2005 at 4:06 PM / IP Logged
yes.
the biggest problem here is that the previous owners broke the remote and decided not to replace it (due to expense).
brwski
hawn13
Copper - Posts: 171
Posted: May 17, 2005 at 6:11 PM / IP Logged
try pulling the fuses in the alarm and disconnecting the brain it should be up under the steering column
infbaffle
Member - Posts: 13
Posted: May 17, 2005 at 6:20 PM / IP Logged
before you go into all this disconnecting and unplugging,see if there is a valet button or switch. sometimes alarm manufacturers run the starter wire and/or other vehicle wires through the brain. if you find one, press the button, turn on the ignition and wait up to ten seconds. this works for most units.
infbaffle
