2001 maxima key fob programming?
Krazzyborri
Copper - Posts: 56
Posted: May 22, 2005 at 3:54 PM / IP Logged
Does anyone know how to program a stock key fob (remote) for a 2001 Nissan Maxima?
Thanx...........
KarTuneMan
Platinum - Posts: 7,056
Posted: May 23, 2005 at 11:00 AM / IP Logged
YUP.....dealer only, needs to be done with the nissan scan tool....
cosmoworks
Copper - Posts: 144
Posted: May 23, 2005 at 7:36 PM / IP Logged
^^ Actually NOT true... it can be done either with or without the Nissan Consult tool.
To program without Consult, do the following:
1) Close all doors
2) Insert key into and remove it from ignition key cylinder more than size times within 10 seconds. Hazard lights will flash twice. (Make sure to remove the key completely from the ignition each time and don't do the procedure too fast, otherwise the system will not enter the registration mode.)
3) Insert key into ignition key cylinder and turn to ACC position.
4) Push any button on the remote once. Hazard lights should flash twice.
5) Open driver side door.
Your welcome 2001 maxima key fob programming? -- posted image.
KarTuneMan
Posted: May 23, 2005 at 7:44 PM / IP Logged
Kool.....
domiyork
Member - Posts: 38
Posted: May 25, 2005 at 12:22 PM / IP Logged
a 1995 nissan maxima same steps??
cosmoworks
Copper - Posts: 144
Posted: May 26, 2005 at 7:30 PM / IP Logged
Yep, '95 can only be programmed with these steps (no Nissan Consult option). Use the same sequence, except you push the "lock" button on step 4.
