01' ford explorer door locks
mxxmikexx
Silver - Posts: 796
Posted: November 18, 2002 at 9:11 PM / IP Logged
from a previous post someone posted that in order to "wake up" the door locks after the vehicle has been left for awhile, you need to pulse a BLACK / YELLOW wire in the drivers kick with a factory alarm disarm pulse from the remote starter unit your using. i wasnt able to find any BLACK / YELLOW wires, but there were a few yellow/black wires  in the drivers kick. does anyone know how to test for this wire, is this wire coming out of the drivers door harness, or is it the other harness that runs down the kick panel to the back of the vehicle?
Player69
Silver - Posts: 504
Posted: November 18, 2002 at 9:17 PM / IP Logged
It will be coming from the drivers door.
mxxmikexx
Silver - Posts: 796
Posted: November 18, 2002 at 9:21 PM / IP Logged
are you sure its not yellow/black?
Player69
Silver - Posts: 504
Posted: November 18, 2002 at 9:23 PM / IP Logged
it's BLACK / YELLOW according to my info.
Player69
Silver - Posts: 504
Posted: November 18, 2002 at 9:35 PM / IP Logged
Did you try checking in the boot to see if it is there?
mxxmikexx
Silver - Posts: 796
Posted: November 19, 2002 at 9:10 PM / IP Logged
when i looked there were about 3 yellow/blacks, but no BLACK / YELLOW coming out of the drivers door harness.
Player69
Silver - Posts: 504
Posted: November 19, 2002 at 9:18 PM / IP Logged
I will look it up in the service manual tomorrow.
Player69
Silver - Posts: 504
Posted: November 19, 2002 at 9:19 PM / IP Logged
Does it happen to have the keyless entry (buttons on the door)?
Player69
Silver - Posts: 504
Posted: November 19, 2002 at 9:21 PM / IP Logged
This is a reguler explorer and not the sport trac correct?
My info shows the sport trac as being yellow/black and says it will be the one with the biggest black stripe.
Player69
Silver - Posts: 504
Posted: November 19, 2002 at 9:23 PM / IP Logged
Another thing you can try, sit in the truck and wait for it to do the bcm shutdown.  Put a key in the ignition (don't turn) and then see if you are unable to unlock the doors.
