keyless entry - Pyle PWD103
vzfox
Posted: June 02, 2005 at 6:41 PM / IP Logged
I have purchased a Pyle - PWD103 keyless entry system for my 2005 GMC Safari.  The book that came with Pyle for the wiring is quite confusing.  I can located the wires I need on my vehicle, but cant figure out what to connect them to on the keyless entry.  It came with one relay also.  Can anyone help....maybe even show/tell me how to wire it up so my doors lock, horn honks and park lights flash??  Thanx.
KarTuneMan
Platinum - Posts: 7,056
vzfox
Posted: June 02, 2005 at 10:05 PM / IP Logged
the diagram in the manual is telling me to connect a wire to the positive (+) side of the horn.  I have found the black (-) horn wire.
mo12v
Posted: June 02, 2005 at 11:06 PM / IP Logged
Make sure you read the instructions......U may be able to change it thru programming or a jumper.....
Otherwise:
If the Unit has a POSITIVE Output for the Horn, then use a Relay to convert it to Negative..................:::
https://www.the12volt.com/relays/page1.asp
If you have a switch or an alarm or keyless entry that has a positive output that you wish to use to switch a device that requires a ground such as a horn, dome light, parking lights, head lights, hatch release, etc., wire a relay as shown below to convert the positive output (trigger) to a negative output.
keyless entry - Pyle PWD103 -- posted image.
MO
