97 Nissan Maxima Door unlock
nima
Member - Posts: 36
Posted: June 06, 2005 at 7:52 AM / IP Logged
         I have problem with unlock the car .its lock the car with remote but not unlock.i connect unlock wire to GREEN/ YELLOW wire on door SW but its not doing anything.any help will be good
mo12v
Posted: June 06, 2005 at 8:56 AM / IP Logged
This vehicle requires a DOUBLE Pulse for Unlock.........
R U using a Double Pulse generator or have you tried the UNlock wire for 1 pulse or 2?
U may require a stronger ground also thru Relays
MO
nima
Member - Posts: 36
Posted: June 06, 2005 at 9:16 AM / IP Logged
I try to connect direct from unit to door lock switch.but its not doing anything.i have buldoge RS122 remote start
can you tell me how to connect the relay.can you send me the diagram
thepencil
Gold - Posts: 1,526
Posted: June 06, 2005 at 10:05 AM / IP Logged
Program the alarm unit to a double pulse first as advice by mo12v. Below is the wire diagram for a stronger ground connection. I think it is a double pulse related issue rather than a ground issue.
97 Nissan Maxima Door unlock -- posted image.
Be careful whose advice you buy, but be patient with those who supply it.97 Nissan Maxima Door unlock -- posted image.
nima
Member - Posts: 36
Posted: June 06, 2005 at 11:57 AM / IP Logged
How to program for double pulse?i have buldoge RS122
thepencil
Gold - Posts: 1,526
Posted: June 06, 2005 at 3:42 PM / IP Logged
OhioMike1101
Silver - Posts: 343
Posted: June 06, 2005 at 9:01 PM / IP Logged
I have done a couple maximas and you hit the DL wires in the door at the cylinder.  You will def need a double pulse for unlock.  You do not need a stronger ground either as you are hitting the wires b4 the factory relays.
I do not believe you can 2 step those DL outputs.  You may just hve to hit the unlock button twice.
