APS-996 Shock Sensor Problems?
ManXP
Posted: June 20, 2005 at 9:37 AM / IP Logged
I have an interesting problem with Audiovox prestige APS-996 alarm system. Every time I disarm my system, siren beeps 4 times and "hammer" icon is displayed on receiver.
Yes, you can say "May be there was an impact", but if I arm my system and disarm it after 1 second for example, it's still the same.
Ideas? Suggestions? Thank you very much...
Teamrf
Gold - Posts: 1,031
Posted: June 20, 2005 at 12:54 PM / IP Logged
Put the key in the ignition and turn it to the on position. Then turn it back off and try it. If it doesn't reset the alarm check your wiring.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
ManXP
Posted: June 21, 2005 at 6:43 AM / IP Logged
Thank you for nice suggestion.
Problem was solved by moving shock sensor to MIN level. I don't know, is shock sensor so sensitive or what?
