1999 Chrysler Intrepid alarm/starter wiring
SLIC Installer
Member - Posts: 14
Posted: June 27, 2005 at 12:01 PM / IP Logged
Hi does anyone have the alarm/starter wiring for a 1999 Crysler intrepid?
thepencil
Gold - Posts: 1,526
Posted: June 27, 2005 at 12:14 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - DODGE / INTREPID / 1999 / Remote Start
12volts pink/black or red    +   ignition harness
Starter yellow    +   ignition harness
Second Starter
Ignition dk. blue/white    +   ignition harness
Second Ignition GREEN/ red    +   ignition harness
Third Ignition
Accessory BLACK/ orange    +   ignition harness
Second Accessory BLACK/ white    +   ignition harness
Keysense
Power Lock WHITE/ green   +   back of fusebox
Notes: Locks are positive trigger through resistors. Use 2.7K (2700) ohms for lock and 620 ohms for unlock. MUST use relays.
Power Unlock same wire
Lock Motor orange      BCM
Notes: BCM is located on the left side of dash with junction block.
Unlock Motor dk. blue      BCM
Parking Lights+ BLACK / YELLOW   +   driver kick panel
Parking Lights- yellow      headlight switch
Notes: Use a 110 ohm resistor to ground (-) for parking lights and a 220 ohm resistor to ground (-) will do both headlights and parking lights.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger tan and tan/red    -   BCM
Dome Supervision yellow   -   rear of fuse box, brown plug
Trunk/Hatch Pin tan/black    -   drivers kick panel
Hood Pin
Trunk/Hatch Release BLACK/ white    +   at release switch
Power Sliding Door
Factory Alarm Arm lt. GREEN/ orange   +   drivers kick panel
Notes: Arm is positive trigger thru a 1.87K ohm resistor, this will also lock the doors. Disarm is positive trigger thru a 680 ohm resistor, if use double pulse this will also unlock the doors. Must use relays.
Factory Alarm Disarm same wire
Disarm No Unlock
Tachometer        one of the coils
Notes: This vehicle has an ignition coil for each cylinder. For tach use a tan/stripe wire at any one of the coils.
Wait to start
Brake Wire WHITE/ tan    +   at brake switch
Parking Brake
Horn Trigger BLACK/ red    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Sentry Key
Part #: 555CW
Alternate Part1 #: 555U
Alternate Part2 #: 556UW
Notes: Only vehicles with gray keys have the immobilizer.
Door Lock Interface Required:
Yes Type:
Multiplex
Part #: 456LW
Notes:
Be careful whose advice you buy, but be patient with those who supply it.1999 Chrysler Intrepid alarm/starter wiring -- posted image.
SLIC Installer
Member - Posts: 14
Posted: June 27, 2005 at 9:19 PM / IP Logged
Thanks a bunch. you are a great help.
SLIC Installer
Member - Posts: 14
Posted: June 28, 2005 at 10:32 AM / IP Logged
Do I need to use the door lock module if I use the relays and resistors or does that module replace the need for the relays and resistors?
thepencil
Gold - Posts: 1,526
Posted: June 28, 2005 at 1:03 PM / IP Logged
I use relays and resistors, but that's up to you. What ever you feel comfortable with use that one. At the end of the day your only concern is getting it to work. 1999 Chrysler Intrepid alarm/starter wiring -- posted image.
SLIC Installer
Member - Posts: 14
Posted: June 29, 2005 at 1:41 PM / IP Logged
thanks. I'll give it a shot with the relays and resistors.
SLIC Installer
Member - Posts: 14
Posted: June 29, 2005 at 10:25 PM / IP Logged
Relays and Resistors worked like a champ. thanks.... but I have a new problem
I used the tan/red and tan wires to connect to my (-) input door trigger on my alarm.
The system false alarms every time because the voltage drops from 12V when the door imidiatly closed to 3.5V a few secons after the door is closed.
My alarm doesn't recognize that 3.5V meens the doors are still secure.
I was wondering if you knew why the voltage drop like that and what can I do to fix the problem? 1999 Chrysler Intrepid alarm/starter wiring -- posted image.
thepencil
Gold - Posts: 1,526
Posted: June 30, 2005 at 9:37 AM / IP Logged
Ummmm....what about using this. Try your luck there.
SLIC Installer
Member - Posts: 14
Posted: June 30, 2005 at 10:59 AM / IP Logged
Thats what I figured the solution would be. the question was more geared toward my curiosity as to why the damn voltage drops... LOL
hopefully that wire doesn't drop in voltage either.
