Keyless Entry Install on 1996 Chevy S10
Ts1996S10
Posted: July 15, 2005 at 12:21 AM / IP Logged
Hi,
I'm wanting to install keyless entry on my '96 S10 truck. I've already purchased the system. It's an Avital "Remote Access 2" I found the trucks wiring diagram on this site, but I was unclear on whether I would need to use relays or not. If anyone has more detailed information on this install and what I will need (relays, other parts, etc.) I would be very grateful.  Thanks in Advance, TS.
gcorrea
Silver - Posts: 436
Posted: July 15, 2005 at 1:12 AM / IP Logged
if the alarm does not come with build in relays then yes you will need to add relays.
gcorrea
Ts1996S10
Posted: July 15, 2005 at 11:39 AM / IP Logged
Well, that's what I'm not sure about. In the installation manual it says under door locks:
"The AMX38 system has a built in two-stage unlocking capability as well as selectable positive or negative lock/unlock outputs. Reverse polarity type door locks require optional relays."
Does my truck have "Reverse Polarity" type door locks? If I need relays, where would be a good source to purchase them from (either on the net or in store). Thanks again for the help.
gcorrea
Silver - Posts: 436
Posted: July 16, 2005 at 12:33 AM / IP Logged
some models are positive if they come with a keyless module, all others are 5 wire reverse polarity,which will require two relays. a good spdt relay will do about 3 to 5 bucks. try ebay or parts express. even radio shack might have them.
gcorrea
Monday, August 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
