Starter Interrup Problem
electriqtion
Member - Posts: 20
Posted: July 18, 2005 at 8:30 PM / IP Logged
I installed a starter kill on a 1994 Suburban using this diagram and the problem I'm having is that the truck will not start when the alarm is disarmed, but will start when the truck is armed. Someting seems to be reversed. Any suggestions to correct this.
Starter Interrup Problem -- posted image.
Electriqtion
Lowron
Member - Posts: 23
Posted: July 18, 2005 at 11:06 PM / IP Logged
If that is indeed the relay setup your using and you wired exactly as shown, there is only one thing to check... Your ground when armed wire. Make sure when you arm your alarm that wire shows ground. Some alarms have a ground when unarmed wire.
Lowron
Member - Posts: 23
electriqtion
Member - Posts: 20
Posted: July 19, 2005 at 9:26 AM / IP Logged
Thats the problem, it shows ground when unarmed, but not when armed. How can I reverse this if it can be? Or is it just the way some alarms are setup.
Electriqtion
Powermyster
Silver - Posts: 962
Posted: July 19, 2005 at 10:31 AM / IP Logged
if you put the stoarter on the 87 instead of 87a
Lowron
Member - Posts: 23
Posted: July 19, 2005 at 11:37 PM / IP Logged
Yeah, that should work. You will need a relay with the 87 pin. Alot of alarms that come with a relay don't have that pin. Move the wire from the 87a onto the 87.
Powermyster
Silver - Posts: 962
Posted: July 20, 2005 at 9:12 AM / IP Logged
i've never seen a relay with only 87A
i've seen 87  think they're SPST
and the and 87A and 87 SPDT
i also have a weird one at home dunno where i found it but it 2 87's on it
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
