2001 gmc yukon remote start
toyotaman78
Member - Posts: 10
Posted: July 20, 2005 at 10:29 PM / IP Logged
I installed a prestige aps996a into a 2001 gmc yukon.  He is bringing the truck back because he says his odometer doesn't work.  He didn't mind it when i installed because it didn't put miles on the display but now he wants to sell it.  I've never had this problem with any vehicle, i didn't know if anyone had ever had this happen.  I checked all the fuses the other day and they were all good. let me know if anybody knows where to start on this one.
thepencil
Gold - Posts: 1,526
Posted: July 21, 2005 at 10:21 AM / IP Logged
It has never happen to me, and I highly doubt that it is realated to Prestige unit that you install.
Be careful whose advice you buy, but be patient with those who supply it.2001 gmc yukon remote start -- posted image.
Powermyster
Silver - Posts: 962
Posted: July 21, 2005 at 11:03 AM / IP Logged
never happened to me.  but cars can be crazy at times.
if its cable the cable goes from teh gear box to the back of the dials perhaps you have pulled at it accidentily.
if its electrical that would be unusual because if the dials work you would have had to snag the right wire coming out of the dials and there is a whole bunch of them that go in   about 25..
also is the speedo working because if its a cable system the speedo won't work if the odo stops they both stop  far as i remember ayway..
so take out the dials and check connections.
hope this helps
toyotaman78
Member - Posts: 10
Posted: July 22, 2005 at 11:39 AM / IP Logged
appreciate the help truck coming in today will let u know
Powermyster
Silver - Posts: 962
Posted: July 22, 2005 at 11:40 AM / IP Logged
good luck hope it fixes easy for ya
accord78
Copper - Posts: 97
Posted: July 22, 2005 at 6:28 PM / IP Logged
first of all forget about the wire to the gear box... beacuse it's all computerized now no more wires. if u installed a prestige i don't think u had to go into the instrument cluster my thought could be is that the cluster took a shhh!! and i know there's some stupid people out there but when he brings it back make sure it's on the odometer setting instead of the trip setting :)
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
